Spark plug Recommendations - JeepForum.com
post #1 of 19 Old 03-13-2014, 04:56 PM Thread Starter
drod77
1997 XJ Cherokee
I'm going to be replacing my spark plugs soon and was wondering what would be a good replacement. Do I go with oe or are there upgrades that I should go with. I have the inline 4.0.
drod77 is offline
post #2 of 19 Old 03-13-2014, 05:52 PM
heitzman
Champion Platinum.
heitzman is offline
post #3 of 19 Old 03-13-2014, 05:59 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Not the platinums. Stick with champion coppers for the 4.0
Sent from inside my dinosoar head.
~James
ezflip is offline
post #4 of 19 Old 03-13-2014, 06:19 PM
heitzman
Correct. My mistake. Copper is recommended by Chrysler.
heitzman is offline
post #5 of 19 Old 03-13-2014, 06:41 PM
fiveseven15
same for the 4.7 non-HO? coppers?
fiveseven15 is offline
post #6 of 19 Old 03-13-2014, 06:54 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Correct. And the HO takes the platinums.
~James
ezflip is offline
post #7 of 19 Old 03-14-2014, 12:26 AM
Johnyre
This should help you
http://www.wjjeeps.com/service/sparkplugs.htm
This place should be your first go to
http://www.wjjeeps.com/jmenu.htm
As I roll down the trail,I hope my traction will not fail.But if I spin & begin to slide,please dear lord protect my ride
https://
http://fortcollinswheelers.com
Johnyre is offline
post #8 of 19 Old 03-14-2014, 04:12 AM
gatorchin
Two years ago when I got my 00 4.7, I had just joined the forum and of course read wjjeeps...they all screamed champion copper..well I was ordered a truck load of parts, couldn't get champions on rock auto at the time, so I got auto lite coppers..two years later after a small lift and bigger tires (put on last year) I saw my mpg drop to 11.3-11.7 on the evic...I finally put champion coppers in a few days ago, (and gapped them properly) and right now my evic is reading 15+ driving in this area ( mountains , lots of curves )..I hit the 4 lane and saw 18 mpg...now I know the evic is off, but just using it as a baseline reading, one can see how important it is to use the correct plugs
00' Laredo w/4.7, 2.5/2" fat bobs coil spring lift, front 3/4" spacer, bilsteins 5100's from Kolak, rear addco w/greasable bushings, 245/16/75 treadwright wardens, 247>242 transfer case swap, all control arms replaced with aftermarket, and lots more $ into various parts
gatorchin is offline
post #9 of 19 Old 03-14-2014, 05:26 AM
86cj74.2L
86cj74.2L's Avatar
You can't even use it for a baseline.
Mine will say 17and math out to 14.5 one tank and read 17 again and math out to 20.7
The coil on plug found on the 4.7 will fire a 3/16 air gap without a single misfire and give a smooth idle. Changing from a autolite to a champion plug will not give you 2 mpg increase. Fuel quality and driving habits will though.
The coil on plug found in the 4.0 is more sensitive to plug type since the spark travels out one plug and in the other. Sometimes they don't like foreign from ground arm to the center electrode of the fine wire fancy spark plugs without a miss. Copper anything is best for the 4.0 and its wasted spark setup.
86cj74.2L is offline
post #10 of 19 Old 03-14-2014, 10:01 AM
ChrisHager
Administrator
ChrisHager's Avatar
Champion RC12ECC (P/N 438). Also rumored from the TJ guys, Champion RC12PEPB5 (P/N 7034).
Gap: 0.035
4.7
Champion RC12MCC4 (P/N 439)
Gap: 0.040
4.7 H.O.
Champion RC7PYCB4 (P/N 3340)
Gap: 0.040
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #11 of 19 Old 03-14-2014, 02:37 PM
corpulent
For the '04 4.0
NGK
4.0L Plug: MoparŪ P/N SP000ZFR5N Gap: 0.035 Torque: 26-30 ft. l
corpulent is offline
post #12 of 19 Old 03-14-2014, 02:55 PM
corpulent
Duplicate post
post #13 of 19 Old 03-14-2014, 02:59 PM
cjcyr8
I used OEM NGK coppers on my 04 WJ 4.0.....AWESOME
cjcyr8 is offline
post #14 of 19 Old 03-14-2014, 08:25 PM
2ndhandWJman
It's very simple. Open your hood and look at the emissions decal, it will tell you what plugs the Jerp left the factory with. Go to a Jerp dealership and buy those exact plugs. It really is THAT simple.
2ndhandWJman is offline
post #15 of 19 Old 03-29-2014, 07:15 PM
kdsimmons19
this guy is onto something. i recently had a guy tell me that since the sparkplugs i bought were so cheap (about $3 a piece on rock), i likely bought the wrong thing. look at the emission decal and the box of new plugs, same damn number.
kdsimmons19 is offline
