Sour smell from air vents - JeepForum.com
post #1 of 5 Old 05-16-2012, 09:58 PM Thread Starter
kaotickustums91
Ok I've got this sour smell coming from my air vents only when the I turn on the ac when it's off you can't smell it are there filters or something in the dash that could get wet or anything like that
kaotickustums91 is offline
post #2 of 5 Old 05-16-2012, 11:29 PM
DubJay99
i have the same issue. Check your radiator hoses make sure theres not a leak. When i turned my AC on it smells like coolant. I purchased new hoses just havent put them on yet.
Kolak OME HD Lift-Bilstein 5100 Shocks-Flowmaster Super 44 HD
Originally Posted by Cebby View Post
(BTW - nice sarcasm coming from a guy who doesn't even have a WJ)
DubJay99 is offline
post #3 of 5 Old 05-17-2012, 12:28 AM
bluevailco
Some cars have filters that look just like your air filer.in The lower vent box by a/c or inner fenders
There intended to catch all that extra dirt an grime from the out side air before going through your cars vents. I had to change one on an Audi a6,after they burned up there clutch because it held the smell.
bluevailco is offline
post #4 of 5 Old 05-17-2012, 12:38 AM
bluevailco
Yes many cars have a filtration system, the filters look just like a normal air filter there intended to catch any extra dirt an grime from roads an out side air.
Normaly located in inner vent box before a/c an many times inner fenders where vent opening starts. I had to change one on an Audi a6 after they burned up the clutch because, It retained the smell an stunk incredibly when vents where blowing air.
post #5 of 5 Old 05-17-2012, 08:15 AM
Double E
Double E's Avatar
That outside air vent is not the cause or solution here. It's more plausable that there's a clog not letting out condensate from the drain tube or as suggested, perhaps an antifreeze leak into the heater core area.
I believe the drain tube is around the front passenger side, behind the front axle. A stiff wire and maybe evena short burst of cleaning agent pushed up there after might be a good way to begin to troubleshoot.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
