Sooo - You polished your headlights.. - Page 2 - JeepForum.com
post #16 of 26 Old 12-16-2013, 05:48 PM
04dubjay
Just a tip. If you end up buying new headlights, throw a coat of wax on them every other time you wash. This helps with the clouding/pitting.
2004 Columbia Edition WJ (I6/Selectrac) -{RC/Ironman4x4fab/JKS/KOR/Nitto/Carolina}
04dubjay is offline
post #17 of 26 Old 12-16-2013, 05:48 PM
bendafinga
2015 WK
I sprayed 3m paint defender clear. When they cloud up I will peel it off and re-apply.
bendafinga is offline
post #18 of 26 Old 12-16-2013, 08:44 PM
snoWJ
I used Colgate toothpaste. It actually worked pretty well haha. (Followed that up with some turtle wax).
1999 WJ 4.0L Selec-Trac~ 2.5" OME coils + 3/4 Front Spacer\\Bilstein 5100s\\245-75-16 Bridgestone Blizzak DM-V1\\Zone Extended Rear Links
snoWJ is offline
post #19 of 26 Old 12-17-2013, 01:06 AM Thread Starter
MadderThanMax
Hope it was the Mrs motorised toothbrush you used otherwise you'd still be there...
MadderThanMax is offline
post #20 of 26 Old 12-18-2013, 09:57 PM
Feldy
2008 WK
I used the mother's headlight restore kit a little while back, i only had to do it again recently because the first time i tried it i had no clue what i was actually doing expect apply and thats it. they stay pretty clean for a long time, i drive on a lot of back country roads a lot so they get put through the test of staying clean.
Feldy is offline
post #21 of 26 Old 12-18-2013, 10:06 PM
wjjeep19
Ive used all diferent kind of kits and they didnt work for me. Surprisingly I already had the tools to do my own restoration without paying for kits. This is what I did: I water sanded my headlights with 2000 and 1500 grit sand paper. Then I buffered the headlights and put a 3M sealant over the headlights to prevent further hazed/fogged lights. If you have a buffer id say do this method as sand paper and 3M sealant isnt costly. It took me about two hours, and yes, your arms get tired. But after being fed up with the kits it was worth it. The results were instant and Ive not had a problem since and its been a year. Hope this helps.
2002 4.Slow
2.5" lift
Software Engineer
wjjeep19 is offline
post #22 of 26 Old 12-19-2013, 01:46 AM Thread Starter
MadderThanMax
Okay.. you've wet my appetite, can you show this 3m sealant and where do you get this?
post #23 of 26 Old 12-19-2013, 06:09 AM
wjjeep19
If its still in my garage ill be happy to show you.
2002 4.Slow
2.5" lift
Software Engineer
wjjeep19 is offline
post #24 of 26 Old 12-19-2013, 06:25 AM
wjjeep19
Sorry, I was hastily looking through my father's garage because it wasn't in mine. He gave it to me. The bottle was old and looked to be from the 1990s but was never opened. Also, what i meant by sealant was that I added a clear coat on the head light, probably can get it at Wal-Mart/Lowes/Home Depot. Like I said, its been a year and no fogging/hazing has reappeared. I recommend that you do this.
2002 4.Slow
2.5" lift
Software Engineer
wjjeep19 is offline
post #25 of 26 Old 12-19-2013, 07:17 AM
Photochop
Get the sylvania kit, it comes with the UV clearcoat that prevents the hazy yellowing from reappearing. I spent about 3 hours on mine, and they turned out pretty good. Not brand new looking - just very slightly cloudy, but since the car tends to show its age a few places it looks like they 'belong'.
Photochop is offline
post #26 of 26 Old 12-19-2013, 07:46 AM
pmdowd6
To answer the OP's question, yes there is a film you can put on the headlights to protect them. Ebay has the cheapest but you'll have to cut it yourself (not hard.)
http://www.ebay.com/itm/12-x-48-Clea...018255&vxp=mtr
pmdowd6 is offline
