Sooo - You polished your headlights.. - JeepForum.com
post #1 of 26 Old 12-16-2013, 10:17 AM Thread Starter
MadderThanMax
Wj Sooo - You polished your headlights..
...to remove your "Clouding". Is there such a thing as a headlight wrap that one done protects the clouding or crazing from reappearing??
MadderThanMax is offline
post #2 of 26 Old 12-16-2013, 10:20 AM
Thomahawk
No but you can subscribe a new set annualy from dealership, shhhh lol
Buildthread
Thomahawk is online now
post #3 of 26 Old 12-16-2013, 10:21 AM
LowLyfe
Id like to find a good answer to this as well. I dont mind polishing mine once every month or so but they start to haze over pretty quick and look bad until I can get to them again. Ive considered just buying a new set but after a polish my current set they look brand new...
02' Jeep WJ Limited Edition - Stock height on Hankook Dynapro ATM RF10's 235/65/17
LowLyfe is offline
post #4 of 26 Old 12-16-2013, 10:24 AM
Thomahawk
I think trer Are differ Brand products with differ results, heard That the 3M kit is Good.
Buildthread
post #5 of 26 Old 12-16-2013, 10:30 AM
Jrboarder27
I used the turtle wax kit that comes with a Sealant and they look perfect six months later
Sent from my Galaxy S4 using JeepForum
Jrboarder27 is offline
post #6 of 26 Old 12-16-2013, 10:43 AM
LowLyfe
Did you go through with the whole scotch brite pad sanding process then polish and seal? I use the turtle wax kit as well but just rub the compound on then wax it off. Have yet to use the sealant but will do the full process next time.
LowLyfe is offline
post #7 of 26 Old 12-16-2013, 10:46 AM
jay-h
If only manufacturers would offer glass lenses again. They lasted decades.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline
post #8 of 26 Old 12-16-2013, 10:53 AM
Jeeples
Jeeples's Avatar
You can clear coat it or you can buy this:
http://www.autoanything.com/lights/6...FYiVfgodeSkARQ
Might shop around though, as that was the first result Google brought up.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #9 of 26 Old 12-16-2013, 11:13 AM
Jrboarder27
Yes I went through the hole process and really took my time on each step it gets tiring but well worth it.
post #10 of 26 Old 12-16-2013, 11:16 AM
Jrboarder27
I've seen those, you can also get different tints and black out your lights at the same time. You can also peel it right of If you don't like it.
post #11 of 26 Old 12-16-2013, 11:39 AM
mycreativename
Do the kit and then clear coat the lenses.
Sent from my blimp fortress using my carrier pigeons.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #12 of 26 Old 12-16-2013, 12:01 PM Thread Starter
MadderThanMax
Or you can buy me a set of headlamps like yours for Christmas
post #13 of 26 Old 12-16-2013, 02:26 PM
AtlasM
2005 WK
I use the Meguiar's kit and then do some basic spray-on wax afterwards. My WJ is pretty new (to me) still but this has worked pretty well on other vehicles.
BTW, here are the results from my recent polishing attempt.
AtlasM is offline
post #14 of 26 Old 12-16-2013, 06:33 PM
BrokeWJ
I've got some set on mine that I haven't had to touch in 4 years. I'm guessing they're not factory...
BrokeWJ is offline
post #15 of 26 Old 12-16-2013, 06:46 PM
R0CKKR4WL3R
I had a "cloud patch" that didn't quite cover the entire lens, but did make it look horrible. I looked into buffing them out, but heard so many more cons than pros, I found in the end it was just easier to replace them...and it was like night and day! Just from changing out the headlights, my '01 went from aged looking to almost new!!! Tack on a few alterations I made and the Jeep looks pretty good! Currently changing out most of the bushings to eliminate rattles, and trying to figure out a cheap solution to a front Pinion ring and seal exchange to get rid of a front end vibration and to regain use of my 4WD, without any luck so far.
R0CKKR4WL3R is offline
