Something died in there - JeepForum.com
post #1 of 5 Old 11-02-2011, 11:24 PM Thread Starter
keith20mm
Oh great....
I parked my 2000 WJ out on the slab for a couple of weeks last month while I had to keep my trailer under cover for a while.
Something climbed/slithered/crawled into the cabin, probably through the gear shift lever hole, or maybe some a/c vent... mouse, snake, gecko, lizard, etc...
and, of course, left droppings around, and then died.
So, in the left rear D-pillar trim is this dead stink, surely coming out of the slots that are just inboard of where the fuel filler door is located, maybe just aft of that, in the left rear interior corner.
I need to remove the D-pillar trim to extricate whatever is dead in there.
Do any forum members have any tips on how to remove the D-pillar trim under the left rear window, without wrecking the plastic or the retaining clips?
The SM shows to remove the liftgate upper trim by pulling downward, and hopefully not breaking any pins off, and then pull the D-pillar trim inward.
So, who's done it, and what to watch out for, other than deadness?
Thanks in advance!
keith20mm is offline
post #2 of 5 Old 11-02-2011, 11:26 PM
Falkon
Falkon is offline
post #3 of 5 Old 11-02-2011, 11:30 PM
Jeepgcl9947
My jeep was sitting for along time and I got in and it smelled horrible there was a dead rat under pass seat don't know how it got there!
Jeepgcl9947 is offline
post #4 of 5 Old 11-03-2011, 11:10 AM Thread Starter
keith20mm
Ok, culprit located and removed... only one broken plastic piece, and that's the just-aft-of-center of panel support which is about 2" tall with a skimpy plastic shell mold pattern.... nothing a quart of JB Weld can't fix. Tip to those pulling panels... use a 1x2 about 16" long to reach down to the clip area, then rotate the stick to pry the clips out. The clips are open on one side, and this allows the clip end to get behind the steel hull. Of course, this will either bend the clip into a somewhat straightened form, pull the other gripper end of the clip off of the plastic fin flange, or tear the plastic flange off of the panel.... mostly, go very slowly.
Thanks, Falkon, for the URL to the panel removal writeup... greatly appreciated.
...and, here's the star:
post #5 of 5 Old 11-03-2011, 11:18 AM
Tezzating
Ahhhh I feel ya pain man ! The overhead computer in my wifes WJ was full of M&M's, Cheezies and mouse dirt, so we spent the whole weekend gutting the thing looking for dead mice, and found their nest in the roof disinfection time !
Tezzating is offline
Died today... jimbo141 WJ Grand Cherokee Forum 29 03-26-2017 11:41 AM
Heater has died and leaks into car Bungy WJ Grand Cherokee Forum 10 02-03-2012 03:56 AM
Starter died AGAIN! steelstr45 WJ Grand Cherokee Forum 20 09-11-2011 09:10 PM
HELP. Jeep just died bjm9818 WJ Grand Cherokee Forum 0 10-15-2010 06:40 PM
Just died. Any ideas? fcarruth WJ Grand Cherokee Forum 0 09-12-2010 11:15 AM
