Some confusion on Trackbar lenght - JeepForum.com
post #1 of 10 Old 11-14-2013, 06:52 AM Thread Starter
golfinWJ
Hey everyone. I'm going to install the 3 inch IRO lift this weekend and I understand all of the instructions and the basics on how to install the lift but I'm still confused on how to adjust the track bar when I'm done with the install. How do I know when it is the proper length and what's the best way to go about centering the axle?
golfinWJ is offline
post #2 of 10 Old 11-14-2013, 07:07 AM
ezflip
ezflip's Avatar
2011 JK Wrangler
Ratchet strap the body to a tree or other object. Center the body over the axle using the ratchet strap (a come along or winch work as well). Install track bar adjusting it till it fits.
~James
ezflip is offline
post #3 of 10 Old 11-14-2013, 07:19 AM
skain8
skain8's Avatar
You don't need to ratchet strap anything. Install the springs, and then simply turn the wheel until the body centers over the axle. Check tire to fender on both sides to verify if eyeballing it isn't enough for you. Then adjust the length of the trackbar so that the holes align. Install the bar and adjust your draglink to center your steering wheel.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #4 of 10 Old 11-14-2013, 07:58 AM
ChrisHager
Administrator
ChrisHager's Avatar
Originally Posted by skain8 View Post
...simply turn the wheel until the body centers over the axle...
This. I made things difficult by ratchet strapping. It worked, but was a pain compared to turning the steering wheel.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is online now
post #5 of 10 Old 11-14-2013, 08:16 AM
PhantomWJ
2003 WJ
If this doesnt work and you body doesnt self centet itself over the axle within less than 1/8" difference on each side, use the ratcheting method above and get the nody over the axle.
Its not that difficult.
PhantomWJ is offline
post #6 of 10 Old 11-14-2013, 08:17 AM
rebelbowtie
I definitely eye balled mine....1/8th I don't think I could tell by line of sight.
rebelbowtie is offline
post #7 of 10 Old 11-14-2013, 08:25 AM Thread Starter
golfinWJ
Okay thanks everyone
golfinWJ is offline
post #8 of 10 Old 11-14-2013, 10:23 AM
Buck89
I used a ratchet for mine but I was able to hook one end to the frame rail and the other to the opposite wheel if I remember correctly and it was pretty simple.
Buck89 is offline
post #9 of 10 Old 11-14-2013, 03:00 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
Also, I didn't have a drag link when I did mine, so the steering wheel method would not have worked anyway.
~James
ezflip is offline
post #10 of 10 Old 11-14-2013, 03:29 PM
Merc1973
Installation instructions:
http://4x4media.info/instructions/jks/JKSOGS127.pdf
2002 WJ Ltd. 4.7 V8, QuadraDrive
1973 Mercury Cougar Xr7 convertible 351CJ, C6, 9" rear
1970 Kaiser-Jeep M35A2 W/OW 6x6 Multifuel D-Turbo.
ΜΟΛΩΝ ΛΑΒΕ!
Merc1973 is offline
