Soft Brakes...any fixes? - JeepForum.com
post #1 of 8 Old 07-20-2014, 11:29 AM Thread Starter
Jayybirdd
I have really soft brakes..when I put the jeep into gear I can even hear the brakes creeking loud..
I can push the brake pad all the way to the floor..one time I had to slam on brakes..i didn't know if I was gonna stop in time lol
is there any way to tighten up the brakes??
I know after driving my jeep then driving my wifes car..i find myself barely touching her brakes
Jayybirdd is offline
post #2 of 8 Old 07-20-2014, 11:47 AM
jetrinka
The first thing i'd do is jack up all 4 corners and have someone apply the brakes while you go try and turn each wheel by hand just to ensure each caliper is at least doing something.
Then i'd take off all 4 wheels and remove the calipers so you can access the slide pins. Make sure none of them are seized and while you are in there use some silicone brake lube on them to make sure they slide easily within their bores. Sticky or seized pins can present themselves as a soft pedal.
Flushing the brake fluid out will get new, good fluid in there and ensure there aren't any air bubbles in there. Brake fluid absorbs moisture and if the content gets high enough, it lowers the boiling point of the fluid which in turn if the brakes get really hot, can boil the fluid and create air bubbles which makes a soft pedal.
What kind of pads are you using? In one of my cars I decided when I did the brakes i'd just use cheap 15 dollar pads made by Monroe from the parts store. I ended up re-doing them almost immediately because they literally would not stop the car. Perhaps it was a defective set but I put a good set of pads on and it was immediately 100 percent improved.
jetrinka is offline
post #3 of 8 Old 07-20-2014, 11:50 AM
alfaitalia
Soft brakes can be caused by;
Air in the lines.....most likely. Bleed thoroughly to cure.
Air in the abs unit. Drblll needed to bleed the unit.....so probably a trip to the dealer.
Sticking caliper pistons. Rebuild or replace caliper. Very common also.
Master cylinder beginning to fail. Replace.
Sent from the Dark Side using only the Force.
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
post #4 of 8 Old 07-21-2014, 09:42 AM
Jeeples
Jeeples's Avatar
Assuming(!) that your braking system is in good working order, then the 'soft' feeling brakes could very well be normal. Scroll down to 'New Features and Options for 2003 models', sixth item on the list:
http://www.wjjeeps.com/newoptions2.htm
I can feel a noticeable difference in pedal effort between my '00 WJ and my wife's '03. I do find it a bit disconcerting that I can apply the pedal almost all the way to floor on her '03, however driving the two back to back, I do feel that the '03 brake system provides a more linear feel in braking, while my '00 almost feels on/off when applying the brakes.
I think what bothers most people is that our instinct tells us the hard we push the pedal, the more resistance we should feel. In the case of '03+ WJ's, the harder you push the farther the pedal travels to the floor.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #5 of 8 Old 07-21-2014, 03:33 PM
alfaitalia
"Reduced brake pedal effort allowing shorter stopping distances during braking maneuvers, accomplished by increasing the master cylinder output pressure for a "lighter" brake pedal feel.".....does not mean longer travel and softer brakes....quite the opposite in fact.
Means less pedal effort for more brake result....ie sharper brakes requiring less pedal pressure and movement....and therefore more linear (linear meaning the harder you push the more force you get) braking in reponse to pedal pressure.
If any car has brakes that does not stop faster the further the pedal is pushed down then it has a problem with the brakes.....and would fail the annual safety check in the UK.
IMO your 03 needs attention if that is how your brakes behave.
post #6 of 8 Old 07-21-2014, 07:42 PM Thread Starter
Jayybirdd
I don't even know where to start. Good thing I drive slow and cruise
post #7 of 8 Old 07-21-2014, 07:45 PM
Trav1s
Basic things to consider:
- flush brake fluid and bleed system
- make sure all parts are working as expected
- replace flex lines with new or braided stainless lines
I have the same problem with my '04 Columbia but I have not tackled it.
04 Columbia Ed 4.7 HO/QTII/SSD107/UC/Bilstein 4600/RB4/Moabs/Cooper Discoverer AT3's/PML trans pan
Trav1s is offline
post #8 of 8 Old 07-22-2014, 08:39 AM
Jeeples
Jeeples's Avatar
Perhaps I wasn't very clear.
I never said that braking isn't increased the farther I push the pedal on our '03. I can push the pedal near to the end of its' travel fairly easily, whereas on my '00 its extremely difficult to push the pedal the same distance due to how firm the pedal becomes near the end of travel.
I agree though, if you can push the pedal to the floor without a noticeable increasing in braking then you need to start looking for worn or failed components .
Jeeples is offline
