So there is ALREADY a transmission cooler on my 04 WJ? - JeepForum.com
post #1 of 13 Old 07-08-2010, 08:10 PM Thread Starter
KDOG2008
So took the beast in for a transmission service - nothing wrong just changing fluid, cleaning it out, etc... and I asked him to look at it and see if I could put a heavy duty transmission cooler in there since I tow a camper. After a while he came back to me and said there is already a small one in there that is built into the same one as the A/C radiator. Its like the top 4-5 inches. He said he was uncomfortable with cutting the existing lines and putting another radiator infront of that one too, and said it doesn't really have room for it. So I didn't have one put in.
I also asked him to assess my vehicles tow capability and made sure I explained to him the whole sordid tale with finding out I had 3.55 diffs instead of the 3.73s, etc. He seemed to think I would be around 4200-ish lbs.
So what do you think? Will the stock transmission cooler be ok for towing around that weight? I don't pull my camper everywhere - usually twice a year 200 miles each way and we stop a few times on the way.
KDOG2008 is offline
post #2 of 13 Old 07-08-2010, 08:41 PM
WJChris
WJChris's Avatar
Trailer hitch packages, in general, are divided into four classes. Class I and Class II are usually designed to be weight-carrying with use of a ball mount. The Grand Cherokee WJ uses Class III and Class IV, which can carry heavier loads with the use of a weight-distributing hitch assembly that distributes the weight to all trailer and vehicle axles. A ball mount can also be used with Class III and Class IV Hitch Receivers for lesser loads.
Trailer Tow Prep Group (requires I-6 engine)
  • 3.73:1 axle ratio
  • Mechanical cooling fan
  • Trailer tow wiring assembly
Trailer Tow Group Class III (requires I-6 engine)
  • 3.73:1 axle ratio
  • Transmission oil cooler
  • Frame-mounted receptacle for load-equalizer type hitch
  • 7-into-4-way plug adapter
Trailer Tow Group Class IV (requires V8 engine)
  • 3.73:1 axle ratio
  • Power steering cooler
Read this:
http://www.wjjeeps.com/trailer.htm
WJChris is offline
post #3 of 13 Old 07-08-2010, 08:54 PM Thread Starter
KDOG2008
Yes I see that, and I have a class III receiver with weight distributing hitch and sway bars, but remember I have 3.55s not 3.73s....
KDOG2008 is offline
post #4 of 13 Old 07-08-2010, 09:08 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
then you have only the shared cooler in the radiator, not in the condenser....some people should only be swapping parts they're told to, not trouble shooting.
ratmonkey is offline
post #5 of 13 Old 07-08-2010, 09:09 PM
WJChris
WJChris's Avatar
You have an aftermarket hitch then?
5000 Pounds.
More from WJ Jeeps:
http://www.wjjeeps.com/dimensions.htm#Towing
WJChris is offline
post #6 of 13 Old 07-08-2010, 09:46 PM
comptiger5000
Look through the grille. If there's an aux cooler there, you'll be able to see it sitting in front of the A/C condenser.
comptiger5000 is offline
post #7 of 13 Old 07-09-2010, 06:24 AM
86cj74.2L
86cj74.2L's Avatar
If you have a hydraulic cooling fan the top portion of the condencer is the cooler for the power steering.
Mopar says in a info packet that 03 and 04 require no aux trans cooler with the tow package. It appears they enlarged the finn and plate cooler in the rad to account for the statement.
Does that mean you can't put one in.......no.
86cj74.2L is offline
post #8 of 13 Old 07-09-2010, 06:44 AM Thread Starter
KDOG2008
Aaaah.I did not know that! That would clear up a great many things. Do you have that info packet? That would be an interesting read....
KDOG2008 is offline
post #9 of 13 Old 07-09-2010, 07:14 AM
comptiger5000
I'm sorry, but IMO, that's CRAP. The issue with running only an in-radiator cooler is that when towing uphill in HOT weather, you can heat soak the radiator, so even the cold side is running 190+. When that happens, your tranny can easily be running 230* or hotter, and you end up cooking it. Always run an aux cooler when towing.
post #10 of 13 Old 07-09-2010, 08:21 AM
SplitNail
I put a new one on. It works great. I broke mine while replacing the radiator.... Dont ask... anyways, it was simple and cheap.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #11 of 13 Old 07-09-2010, 03:43 PM
86cj74.2L
86cj74.2L's Avatar
I can not find the PDF from Jeep where its in. It had a title along the jist of towing with your jeep. Or something to that effect.
If you install one put it between the trans and rad cooler flow wise. It will help maintain proper trans temps in the winter. That is how the factory Aux coolers were plummed.
post #12 of 13 Old 07-09-2010, 04:27 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
aux coolers should be installed on the RETURN line.
post #13 of 13 Old 07-09-2010, 08:00 PM
86cj74.2L
86cj74.2L's Avatar
My Ram with a Cummins has it the way I stated. The only time I saw it the other way is if it was put on after the fact.
In a warm climate it is ok. In a cold climate its not ok. to put it in the return line. (unless you spend the big bucks for one with a temp controlled bypass valve.....but the valves fail and create back pressure and ending wiping out the trans.)
On the newer electronically controlled transmittions cool oil is not always better. If the oil going into the trans cooler is colder then the coolent then it will aid in cooling the engine coolent. It works both ways.
transmission , cooler , factory
Transmission Cooler bmwguy27 ZJ Grand Cherokee Forum 23 02-23-2010 09:20 PM
Transmission cooler on 07 WK dalefan4lyf WK Grand Cherokee & XK Commander Forum 10 07-04-2008 04:31 PM
Transmission cooler fisher1630 ZJ Grand Cherokee Forum 13 02-25-2008 06:29 PM
Transmission Cooler staggwj ZJ Grand Cherokee Forum 11 11-03-2007 04:57 PM
Transmission Cooler bill9000 ZJ Grand Cherokee Forum 1 07-18-2006 12:05 AM
