Quantcast So I took it to a shop..... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > So I took it to a shop.....
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 03-09-2010, 04:11 PM   #1
Inavacuum
To get the door harness repaired. I know I know, I just hate messing with wiring and the door harness is such a tight space, there were some broken pins and I just didn't want to deal with it.
So I took it to a place that is said to be the best local place to take stuff for electrical issues. So the symptoms are, no locks, no windows and nothing coming outta the speaker.
$110.16 later we have locks and windows but still no speaker. The guys cut the rubber cover that goes over the harness (the big black one you see when you open the door, and that keeps mud,sand,water out of the connections). Totally just sliced it open to get to the wires, instead of doing it the right way. And because the pin for the lock circuit was broken, the guy drilled a hole into the door and ran a write through with connections on either side.
So. Now I have no way to take my door off to replace the hinge pin bushing that is shot, and no way to quickly take my doors off to make the tube doors I wanted to as it warms up. AND nothing to keep mud and crud and debris out of the door harness.
What do I do?
95 ZJ 4.0 PART OUT: Silver Body; Grey Cloth interior
HPD30;RE BB w/ RE Shocks;KOR Rad Support
KOR XMember/TC Skid
Make an offer on anything you're interested in.
Inavacuum is offline   Reply With Quote
Old 03-09-2010, 04:15 PM   #2
jplifee
take some photos of this wack job repair i am kinda confused.
i would also have them order you a new boot for the door first thing.
and are they ASE certified electrical techs?
1989 Comanche Long bed 4.0 auto
127,000 and toasted
1999 Grand Cherokee Limited 4.7
160,000 and counting
jplifee is offline   Reply With Quote
Old 03-09-2010, 04:32 PM   #3
Inavacuum
The red wire going into the green gromet is the lock wire. He said that the pin was broken and so he did this. If you look at some of the wires in the harness they're still obviously have insulation exposed.
KOR XMember/TC Skid
Old 03-09-2010, 05:00 PM   #4
IronMaiden
Hallowed be thy name....
IronMaiden's Avatar
1982 CJ8
That sucks but that's what you get for being lazy and having someone else work on your Jeep.
Brand new nutmeg rear CJ/YJ seat, new AX5 clutch kit, 5.9 louvers, etc.
Click Here - For Sale
79' CJ7
82' CJ8
94' YJ
96' ZJ
IronMaiden is online now   Reply With Quote
Old 03-09-2010, 05:09 PM   #5
jplifee
you could just duct tape it all up and get some sort of electrical connector that is easily un plugged.
or take it back and tell them that isnt a clean job at all and you want some sort of connector put in.
water proofed and insulated.
im not sure if you can but sometimes you can get replacement pins and connectors the push into the connector box , you need a special screwdriver.
127,000 and toasted
Old 03-09-2010, 05:42 PM   #6
Inavacuum
Are you serious about the duct tape?
And yes you definitely can do that, thats what I expected to be done. I expected the harness to be unplugged at both ends, pulled off the jeep, the broken pins/wires replaced and the harness re-installed.
KOR XMember/TC Skid
Old 03-09-2010, 06:57 PM   #7
IronMaiden
IronMaiden's Avatar
1982 CJ8
Not trying to be a jerk, but you get what you pay for.
Did you seriously think that they were going to do all of what you just said for $100?
Did you even speak to them about what the game plan was when you dropped the Jeep off?
79' CJ7
82' CJ8
94' YJ
96' ZJ
Old 03-09-2010, 07:02 PM   #8
Falkon
My dealer, & I usually can think of nothing good about them, repaired mine in a half hour. They soldered the broken wire & 2 others that were weak, covered in shrink wrap etc. That's how DC recommends the repair be done. You were taken by a very sloppy repair facility. Hate to see how they do work you cannot see. I'd never go back there again.
Falkon is offline   Reply With Quote
Old 03-09-2010, 07:17 PM   #9
rustynail
Location: Vancouver, British Columbia, British Columbia
That sucks........... there's no excuse for that crap job.
- Russ
5.9 ORVIS 33x12.5 MTR-Kevlar, 7" fr adj IR LA's, 7" rr adj RE SF SA's, adj JKS TB's, RE SB disc, RE Springs, JKS ACOS, 13" RS9000XL's, OME SS, NP231, Durango box, IR Sliders, IR Skid, 3" Flowmaster 70, K&N, Superwinch EPi9.0, Optima Yel, 2 air comp, Alpine, Garmin, Sunroof
rustynail is offline   Reply With Quote
Old 03-09-2010, 09:50 PM   #10
vansskaterfreek
i would never think about doing that to a customers car, lol that is a horrible job.
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline   Reply With Quote
Old 03-09-2010, 11:16 PM   #11
jplifee
yeah serious about the duct tape, i wouldnt want any water or crap getting inside there, it was insulated in the first place for a reason. at least a temp fix until you get the new rubber boot that they sliced.
127,000 and toasted
Old 03-09-2010, 11:25 PM   #12
WiCkeDuDe
WJ Jedi Master
WiCkeDuDe's Avatar
x1000. That is some horrible work. I cant believe they would think thats ok.
WiCkeDuDe is offline   Reply With Quote
Old 03-09-2010, 11:49 PM   #13
ZJ5point2GCL
at least they used a grommet
98 Deep Slate Niner- 6''s on 33's ---11 F150 Platinum Pearl White- Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline   Reply With Quote
Old 03-10-2010, 06:39 AM   #14
Inavacuum
So, dropped it off early this morning before they opened on the way to school. The guy said they had to do that because the pins were broken off. I feel like he just clearly has no idea of how the repair should properly be done. I don't think I'm going to risk anymore potential damage done. Just don't know where to take it now, that was the place everyone said to go to for electrical problems.
Also, just to verify that I'm not insane. It is possible to both totally remove this entire harness from the jeep and replace broken pins on the door side of the connection, correct??
KOR XMember/TC Skid
Old 03-10-2010, 06:47 AM   #15
Savasa
Greetings,
Vacuum, that sucks! Yes it is possible to replace individual pins. Pins or spade clips or whatever usually have some sort of locking tab where they fit into the plastic socket. The trick is to depress this tab and pull out the old pin. Can't say without seeing your set up but I've used a thin scribe to slide down between the pin and the plug to release the locking tab.
Peter.
Savasa is offline   Reply With Quote
Glock Forum
