Sneak peak... pic of Bushwacker's NEW cut-out fender flares!! - Page 56 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Sneak peak... pic of Bushwacker's NEW cut-out fender flares!!
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 01-02-2013, 07:37 PM   #826
Maximus_Daximus
1976 CJ7
yea, it looks so little. like a cj sitting on a golf cart frame.
current build 1999 wj [url]http://www.jeepforum.com/forum/f22/metal-mulisha-wj-1382820/[/url]
previous build 1976 cj7 [url]http://www.jeepforum.com/forum/f22/76-cj7-nothing-something-1080909/[/url]
Maximus_Daximus is offline   Reply With Quote Quick reply to this message
Unread 01-03-2013, 06:14 AM   #827
D0dgeRam1500
Call Kolak and buy his OME lift kit. She will look great then.
2014 Dodge Charger R/T AWD Sport - Daily Driver
2005 Jeep Wrangler Willys Edition - Weekend Toy
D0dgeRam1500 is online now   Reply With Quote Quick reply to this message
Unread 01-06-2013, 06:00 AM   #828
northpaw
Originally Posted by team1k
My wifes grand had a rust spot right behind the rear passenger door so in looking for a solution a friend referred me to thsese flares. Just got done installing them. I included some pictures that show what sections get cut out and hope they may help others in determining if these are right for them. You also get to see what they look like on a stock jeep, you know in case you were wondering
Can you tell me why you have to cut the cladding?
1999 Jeep Grand Cherokee LTD
4,7 Litre V8 Quadratrac II
4 Hella 320, 4 Boch Big Knick, JULA Roof rack, 245/75/16 General Grabber AT2, IRO 4 inch Lift kit
northpaw is offline   Reply With Quote Quick reply to this message
Unread 01-06-2013, 03:45 PM   #829
team1k
Sure. The flare mounts on the door and they molded that section to fit the door without the cladding on. I'm not a grand guy but I suspect 1 reason is there are probably different styles of cladding, 2 is it probably fits better if not going over the cladding. Cutting the cladding really wasn't too bad. I did however break two of the body clips on the back when taking them off so be careful. Feel free to ask more questions and I'll do my best to answer.
It was a Jeep thing, but all that stuff broke
92 Jeep YJ Wrangler
UJC
"YJ's are for poor people" - Brian
team1k is offline   Reply With Quote Quick reply to this message
Unread 01-07-2013, 11:27 AM   #830
northpaw
So you got a good snug fit? I think it must be hard to get a correct line in the cladding, and a smooth surface that fits with the flare.
Also, did it compromise the weather proofing of the door? I mean did it mean that you have to have some holes in the side of the door where water might leak in when crossing waterstreams?
Unread 01-07-2013, 01:28 PM   #831
team1k
Yeah I was actually very surprised with how well it contoured to the body. They even give you extra pieces for the rear section in case you have a limited or a Laredo just so it will fit the different body styles.
It uses screws to hold itself on so maybe if you completely submerged a section for a bit then water could slip past, however I put silicone on all the holes and the screw itself when I put them in so i don't see that happening. When you cut the rear wheel well pinch seam it does exposť the sound deadening material inside the door. What I did was put por-15 on all my cuts and the area around them, then I filled in the gap with body adhesive. Shouldn't rust now and it's sealed shut.
92 Jeep YJ Wrangler
UJC
Unread 01-07-2013, 06:43 PM   #832
Gafford44
2003 WJ
The title should be changed in this thread to post pictures of your bushwacker fender flares
03 WJ Limited White : 2" BDS Springs - Blistein 5100 Shocks - Retrofitted Headlights HIDS - Flowmaster 10 series - 20% tint - Tinted taillights - Complete Audio Upgrade
Gafford44 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2013, 09:00 PM   #833
Timbo24
If you insist haha here are mine with Iceland front bumper sorry about the snow. Ill get some better ones soon.
Timbo24 is offline   Reply With Quote Quick reply to this message
Unread 01-08-2013, 12:22 AM   #834
texlurch
I have a new in box set.. planned to get the aftermarket bumper but the ones I want aren't made anymore
Not sure I like how the front flare is wider than the stock bumper so may not be using them after all.
texlurch is offline   Reply With Quote Quick reply to this message
Unread 01-18-2013, 06:42 AM   #835
D0dgeRam1500
Bump for more pictures!
Unread 03-17-2013, 08:00 PM   #836
mustangwarrior
they do look good, just got my lift on today, my dad suggested flares but i really didn't want to put out the money for them, however on my test drive today i realized that i have some trimming to do yet so the cutouts will help and after pulling down my buddy's gravel drive i realized with 3.65" of backspacing, i will never be able to keep this thing clean
KCCO! -Nick
2001 Jeep WJ, I6, Select Trac, IRO 3", Cooper ST maxx 265-75, 16" Raceline Rockcrusher Wheels, Custom Tire carrier, 30" Seward LED Light bar, rear Aussie Locker
mustangwarrior is offline   Reply With Quote Quick reply to this message
Unread 03-17-2013, 08:05 PM   #837
Maximus_Daximus
1976 CJ7
pics
Sent from your moms tablet
Unread 03-18-2013, 01:27 PM   #838
mustangwarrior
Ok so 4wd has them listed as a set for $549, add to cart they drop to $479,
Or you can buy them separate in front and rear sets and after added to the cart they drop to $395,
Anyone know why they are cheaper to buy separate? Everything looks to be the same, i might have to jumper on them at $395, sure beats $549
KCCO! -Nick
Unread 03-18-2013, 01:36 PM   #839
chris1999wj
Id go through kolak, great service.
99 wj 4" rcx lift, 275/75/16 kenda m/t km29, safari bull bar, wp safari roof rack, adj. control arms and track bar, rc steering stabalizer
chris1999wj is offline   Reply With Quote Quick reply to this message
Unread 03-18-2013, 02:35 PM   #840
mustangwarrior
Their page says 20% off for st patricks day ends tonight, so i think thats why they get cheaper in the cart, but i doesn't make sense why they are cheaper separate
KCCO! -Nick
