Smittybilt XRC8 or Superwinch LP8500 - JeepForum.com
post #1 of 16 Old 05-02-2012, 12:23 PM Thread Starter
fosterjd79
What do you all think? Which is a better buy? Both are 299.99 + shipping. The superwinch is rated at 8500lbs and the Smittybilt is 8000 but that's not enough to sway my decision. I'm a weekend warrior on the trails and want the piece of mind of being able to winch out when alone. Warn is too expensive so let's stick to these two for now.
fosterjd79 is offline
post #2 of 16 Old 05-02-2012, 12:32 PM
conkatonk
smitty
ConkaTonk
04WJSE
conkatonk is offline
post #3 of 16 Old 05-02-2012, 02:08 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Can't go wrong with either.
I got the Smitty because it was in-stock at 4WP and I could go pick it up immediately before the wife changed her mind about me spending $700 on the Jeep (for receiver, winch cradle, winch, and wiring).
The XRC8 has a great reputation as a good, reliable budget winch. Superwinch has a great reputation too.
Let's compare amp draw, pulling power, and line speed. Some winches fall off quickly in power with added wraps. Bear with me I don't know what the results will be here.
SmittyBilt
Wrap 1 8000 lb
Wrap 2 6900 lb
Wrap 3 5850 lb
Wrap 4 5100 lb
So it drops from 8000 down to 5100lbs on the outermost wrap of cable.
Line speed and amp draw (first layer)
No load 37.2 fpm, 75A
2000 lbs 18 fpm, 195A
4000 lbs 13.1 fpm, 260A
6000 lbs 10.2 fpm, 335A
8000 lbs 8.2fpm, 410A
Superwinch (still looking for data on pull by number of wraps)
No load 18 fpm, 84A
2500 lbs 9.8 fpm, 156A
4500 lbs 7.5 fpm, 215A
6500 lbs 6.0 fpm, 270A
8500 lbs, 3.5 fpm, 320A
My conclusion here is that the LP8500 draws a lot less current with the 4.5hp motor than the Smittybilt's 5.5hp motor. The SB has a lower gear reduction 172.8:1 instead of 235:1 and as a result, pulls a LOT faster than the Superwinch. By the time the Superwinch hits 4500 lbs it is lower than the slowest speed of the Smitty.
Both have the same length and grade of cable. I think the Smittybilt wins this comparo, at least on paper.
~Richard
billzcat1 is offline
post #4 of 16 Old 05-02-2012, 03:54 PM Thread Starter
fosterjd79
I ordered the Smitty. Now, what should I do about power? Dual battery? Single dry cell battery? It will be the only aftermarket toy that needs additional power for now although adding some power to the back for an air compressor, camping fridge etc wouldn't be a bad idea.
post #5 of 16 Old 05-02-2012, 04:55 PM
99WJdan
Im also torn between the two. Although I was looking at the smittybilt xrc8 comp with the synthetic line.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #6 of 16 Old 05-02-2012, 05:00 PM Thread Starter
fosterjd79
I found it was less expensive to buy the winch with the cable and buy the replacement synthetic line seperate.
post #7 of 16 Old 05-02-2012, 05:05 PM
billzcat1
2003 WJ
A single good battery will do you fine. I've heard too many reports of Optima's decline in quality of late, I think Sears has the best battery on the market in their Die Hard Platinum line.
I too would buy the synthetic line separately. Smittybilt had an issue about a year ago where they were shipping their XRC8 comps with hooks only rated at 3000lbs. They replaced all the hooks, but I'd go with a name-brand synthetic line with a rated hook/safety thimble over what comes in the box with the XRC8 Comp.
I would love to have synth on my XRC8 though, that winch + cradle is heavvvvy.
~Richard
post #8 of 16 Old 05-02-2012, 05:08 PM Thread Starter
fosterjd79
What about if I add additional accessories in the rear for camping? Won't I need a second battery to power those items with the engine off?
post #9 of 16 Old 05-02-2012, 05:15 PM
billzcat1
2003 WJ
Depends. A lot of "expedition rigs" have a dual-batt setup. But things like the ARB fridge is only like .75A to run. Me? I have a cooler and a bag of ice. Look at "reserve capacity" ratings. I spent about a hundred bucks on a battery to get 1000CA and 150 minute reserve capacity. That's the ability to run 150 minutes with a draw of 20 amps and still be able to start the engine. It's going to take a lot of camping accessories to drain that.
~Richard
post #10 of 16 Old 05-02-2012, 05:18 PM
99WJdan
Good to know about the synthetic line. Ill probably pick up a Viking then. Any idea diameter size?
99WJdan is offline
post #11 of 16 Old 05-02-2012, 05:28 PM
billzcat1
2003 WJ
3/8 is overkill but provides a good safety margin for abrasion.
~Richard
post #12 of 16 Old 05-02-2012, 05:32 PM
99WJdan
Good to know. Looks like I will be ordering this: http://www.amsteelblue.com/item/AB516125TCR/ along with my winch too.
99WJdan is offline
post #13 of 16 Old 05-02-2012, 05:36 PM Thread Starter
fosterjd79
Yes, but price that, I'm sure you can find it for much cheaper.
post #14 of 16 Old 05-02-2012, 05:39 PM Thread Starter
fosterjd79
Ok, I understand the battery issue. I was trying to spoil myself really. Maybe thoughts for another day.
post #15 of 16 Old 05-02-2012, 05:43 PM
99WJdan
Ill spend a whole day trying to get it at the lowest price haha. That seams to be a habit before buying anything now along with a good full day of reviews/research.
99WJdan is offline
Smittybilt G.E.A.R Seat Covers BCobe WJ Grand Cherokee Forum 8 04-20-2011 07:51 PM
