sluggish acceleration, stumbling... no codes, fuel pressure 50psi, ahhh help please! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > sluggish acceleration, stumbling... no codes, fuel pressure 50psi, ahhh help please!
The Original 3/8" Ruffstuff Diff Cover!The Cure for your Tie Rod Roll!1976-1986 Jeep CJ7 with Stationary Vent Windows Weatherstr
Unread 05-08-2014, 12:40 PM   #1
smcg3
Unhappy sluggish acceleration, stumbling... no codes, fuel pressure 50psi, ahhh help please!
4.7L stumble on acceleration at medium throttle, and is generally sluggish and jerky under heavy throttle. Stumbling/jerking at medium throttle is beginning to get worse. Funny part is, at light throttle/cruise you don't notice anything, and the car gets normal mileage (19-21 indicated). But as soon as it is more than light throttle, there is no power, engine has to downshift twice to get any acceleration.
I checked the fuel pressure, and it is a steady 50psi at ALL throttle positions. I'm getting no codes, which suggests to me it's not a knock/O2 sensor. I pulled the throttle body off and cleaned inside, including inside the port of the sensor on the lower right hand side. I also checked tranny fluid, and it is at a normal level. I'm a bit stumped and could use some guidance.
I am figuring if it was a misfire/no fire in a cylinder, the knock/O2 sensors would say something. I'm wondering if it maybe a sensor? I've read throughout the forums that the CPS and TPS can be suspect, and they can cause these symptoms. However most of the posts I read were regarding the 6 cylinder, so I'd love some additional thoughts on the V8.
smcg3 is offline   Reply With Quote Quick reply to this message
Unread 05-08-2014, 01:36 PM   #2
smcg3
Another thought: is it possible it's a vacuum leak? If so, where is the best place to start looking? What testing methods does everyone use? I've heard of using carb cleaner, as as well as the "smoke test".
Unread 04-13-2015, 06:03 AM   #3
Double E
2000 Laredo V8
Double E's Avatar
SMCg3,
What was the resolution to this?
2000 Laredo 4.7L Selec-Trac. 177K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 4X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X), new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side, new Durango alternator. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is offline   Reply With Quote Quick reply to this message
Unread 04-13-2015, 06:36 AM   #4
mudpack
Originally Posted by Double E View Post
SMCg3, What was the resolution to this?
Yes, please.
You ask us for a service for you (advice), we'd like a service in return (tell us the answer). It's all about being a useful part of the Jeep community.
mudpack is offline   Reply With Quote Quick reply to this message
Unread 04-14-2015, 07:24 PM   #5
smcg3
Bad spark plug #6 cylinder. It threw a code implicating the #6 cylinder for something else, and I checked the spark plug as part of the testing and found it to be very worn. Checked all the others and they were quite worn as well... guess the owner before me hadn't changed them in awhile! Once I swapped the spark plugs it made a world of difference. Glad I was able to solve this one on my own!
