slow crank 4.7 - JeepForum.com
post #1 of 8 Old 09-06-2010, 10:36 PM Thread Starter
CoolGuyDave
slow crank 4.7
i know this has been covered over and over but id like a second opinion before i spend 180 bucks on a new starter. So it cranks slow, had an old battery in it so i replaced it with a diehard gold. didnt fix the prob (the terminals are clean and tight). Put a meter on the batt and it reads 12.3v. while running its 13.6v. while cranking its 9.XXv. lights are nice and bright... never dim, but it still cranks slow, almost to the point where it sounds like it will stop turning over. i bought the jeep used so i dont know much of its history. but i do know its been replaced before (has an AC Delco starter in it). What are some other things i can check before i make the jump and buy a new one? thanks jeepforum!
-dave
2002 Overland
NIU Mechanical Engineering Grad
"EAT, SLEEP, JEEP!"
CoolGuyDave is offline
post #2 of 8 Old 09-07-2010, 01:01 AM
PCJona
its definitely the starter. sorry bud.
just happened to me last month.
PCJona is offline
post #3 of 8 Old 09-07-2010, 08:55 AM
jfyfe
I'm with PCJona - Sounds like a starter. Pull it and have the auto parts guys test it if you want to make sure. Only other thing I can think of is the taps on the starter are a bit loose, but that is probably unlikely.
jfyfe is offline
post #4 of 8 Old 09-07-2010, 10:57 AM
mudthang
1977 CJ5
I had a similar problem but my starter tested out fine. I was only getting 6 volts at the starter while cranking. I replaced the battery cables and it fixed the problem.
I did the positive cables first and I was still only getting 6 volts. So I replaced the negative cables next and it started right up.
1977 CJ5 - 304 V8
1999 WJ - 4.7l V8
mudthang is offline
post #5 of 8 Old 09-07-2010, 12:52 PM
nlynd1978
2006 XK Commander
1. Remove the starter have it tested.
2. check and replace cables.
3. Did you buy the correct battery or the cheap it will fit kind.
Had a simalar problem with my friends car, he bought a brand new battery but only got a 500 cca battery when he needed a 800 cca battery. car would still start but cranked really slow. We checked everything else before i noticed it was the crappy battery he had. Also, just cause its new doesnt mean its good. I got a brand new battery one time for my bike. It was DOA when i got it. Didnt know till i put it in the bike, which would not start still, and took it to a shop. And you can have 12v's on a battery but get no amperage. Just had that problem with another car i was working on the other day. My advice remove the battery and starter and take them in for testing, replace as necessary.
06 Commander Limited,4.7,130k
01 GC Limited,QD-II,4.0,236k-sold
99 GC Laredo,QT-II,4.7,96k-Sold
nlynd1978 is offline
post #6 of 8 Old 09-07-2010, 02:35 PM Thread Starter
CoolGuyDave
nope.... bought a DieHard GOLD 900+ CCA. i'l check the cables over before i buy a starter. thanks.
2002 Overland
"EAT, SLEEP, JEEP!"
post #7 of 8 Old 09-07-2010, 06:30 PM
Double E
Double E's Avatar
That volt to amp discussion is valid and even new batteries may still need a charge to attain their rated capacity, but he has no dimming, so I'm in the weak starter camp too.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #8 of 8 Old 09-11-2010, 01:05 PM Thread Starter
CoolGuyDave
put in a "NAPA Supreme Power" starter.... starts right up with ease...
thanks all
2002 Overland
"EAT, SLEEP, JEEP!"
clicking/popping when braking at slow speeds. ruggedscotsman WJ Grand Cherokee Forum 8 06-17-2011 10:01 AM
242 Selec Trac - 4wd Slow To Engage xSnoWx WJ Grand Cherokee Forum 11 08-31-2010 06:35 PM
99 WJ 4.7 turns over slow, doesn't want to run when started bigredjeep95 WJ Grand Cherokee Forum 5 07-21-2010 10:22 PM
2001 WJ Slow Oil Leak....Where From? bradbb2005 WJ Grand Cherokee Forum 3 07-09-2010 08:03 PM
!545fre Tranny pops and clunks when i stop or slow!! please help SHOCKER WJ Grand Cherokee Forum 8 05-06-2010 03:49 AM
