slect track 4x4 works on wj, but transfercase makes a clicking sound - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > slect track 4x4 works on wj, but transfercase makes a clicking sound
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 09-11-2010, 10:52 PM   #1
Big-Z
4x4 works, but when ever I putit in, the transfercase makes a ticking ratteling sound. it goes away when back in 2x4
I have a 4 inch lift on my wj.
2nd question. are you supost to back up when disengaging the 4x4? my wj does not have a manuel and I have trouble taking it out of 4x4
thanks guys
Big-Z is offline   Reply With Quote
Unread 09-12-2010, 10:06 AM   #2
RedlegWJ
Internal shift forks have plastic pads on the ends that are probably wore down or gone now, not allowing it to stay in gear or shift in all the way.
RedlegWJ is offline   Reply With Quote
Unread 09-12-2010, 06:40 PM   #3
Big-Z
so is it safe still to use? or will it cause more damage?
Unread 09-12-2010, 07:32 PM   #4
ras2001wj
Hows your transmission mount looking?
[B]Rick[/B]
[SIZE="3"][B]2001 WJ Laredo 4.0[/B][/SIZE]
[SIZE="2"][B]2" BB
245/75R16 [/B][/SIZE]
[B]
[COLOR="Red"]Ron [/COLOR][COLOR="White"]Paul[/COLOR][COLOR="White"][/COLOR][/B][COLOR="Blue"] 2012[/COLOR]
"Freedoms Popular"
ras2001wj is offline   Reply With Quote
Unread 09-13-2010, 01:41 PM   #5
jrschulz
have you checked your fluid lately? mine was making a noise...got down under and looked...had a nice gash in the tcase. no fluid. repaired hole, filled with fluid and noise is gone.
jrschulz is offline   Reply With Quote
Unread 09-13-2010, 03:48 PM   #6
Double E
2000 Laredo V8
Double E's Avatar
Look at your front drive shaft. Each end should have a rubber boot where it comes from the transfer case and again where it goes to the front diff. If those boots are leaking or torn, the drive shaft needs to be replaced. Mine recently had this done and it clicked in everything but 2wd.
2000 Laredo 4.7L Selec-Trac. 161K miles, Leather, 245 tires, tow package, crappy CD changer, full size spare, roof cross-rails & sunroof.
Changes & fixes: Rear Addco sway bar & greasble bushings, upgraded headlights, upgraded tail lights, new hood struts (replaced 2X), new rear hatchglass struts, new radiator (replaced 3X), new oil pressure sending unit (replaced 2X), 2 new speed sensors, 2 new door lock actuators, new ignition key cylinder, chrome front tow hooks, Mobil 1 Synthetic 5/30, Purolator Pure One oil filter, EBC slotted & dimpled rotors, EBC Greenstuff pads, new front shocks (replaced 3X), new rear shocks (replaced 2X),
new IRO steering stabilizer, new timing chain cover, new water pump, thermostat, new thermostat housing, new high pressure power steering hose, Michelin-X radials, new sunroof assembly, new single-piece lug nuts, new exhaust manifold studs & gasket on driver's side. Jeepforum.com sticker, Visit cobaltboatsforum.com when you can!
Double E is offline   Reply With Quote
Unread 09-13-2010, 07:35 PM   #7
narnwv
narnwv's Avatar
x2
Mine's doing the exact same thing. Did some wheeling on it, and now it even does it in 2wd.
~Aaron
NarnWVs Build Thread
2000WJ 4.7 247->242 swap,
Rough Country X-series 4",
K&N, Flowmaster Super 44,
JK Moabs+32" BFG KM M/Ts, Addco rear
custom4x4fabrication rear bumper
Hitch-Mount Tire carrier for sale
Originally Posted by jeep04 View Post
I just drive mine with a helmet on (just in case)
narnwv is offline   Reply With Quote
Unread 09-15-2010, 05:44 PM   #8
Big-Z
ok cool, I will look, I'm going to get a after market shaft anyway eventually, but as long as it keeps up in 2x4.
Unread 09-15-2010, 10:03 PM   #9
rlewi09
yep it sounds like the front driveshaft could definitely be an issue. i have replaced my front driveshaft 3 different times with those same issues, the transfer case twice, and i am about to have to replace the rear driveshaft. i love my jeep to death and wouldn't trade it for anything. but good god they cost a lot of money. especially at 19 years old ha
rlewi09 is offline   Reply With Quote
Unread 09-15-2010, 11:40 PM   #10
Blkdvll
A front driveshaft would make noise in 4x2 and 4x4...
...just sayin...
2004 4.0L w/242 WJ - Front tow points, Rear D Shackel, 3"/2.5" lift, 245/75 Falken ATs, Sway Bar delete, Overland Sliders, T-Case Skid, Hella 500's, Halved Bumper, Custom Rad.Core Skid, Soft 8's, MV50 OBA, Hi-lift/lift mate, shovel, (1st)On-Board Cooler, OME S.S., Rola Basket.....more soon
Blkdvll is offline   Reply With Quote
Unread 09-15-2010, 11:52 PM   #11
narnwv
narnwv's Avatar
...just sayin...
Negative. My tcase side boot was torn, bearings gone, NO NOISE in 4x2, as there is ZERO torque being applied to it. Sure it's spinning, but it's just being pulled along via the front axle. When I put it in part time or full time, torque was obviously applied to it, and it made all kinds of racket.
EVENTUALLY it has started making noises in 4x2, but only after running it 1500-2000 miles on the BB.
~Aaron
Unread 09-16-2010, 10:11 PM   #12
rlewi09
agreed. when i had to replace my front ds it made the noise in 4 wheel drive only. after about 3-4 weeks of driving it like that and engaging and disengaging 4 wheel drive it began to eventually make the same noise, just quiter and not quite as much, in 2 wheel. as soon as i replaced the front ds, all noises were gone.
Unread 09-17-2010, 07:26 AM   #13
Double E
2000 Laredo V8
Double E's Avatar
Me too rlewi. New shaft = no noise.
Mebane!!!! I went to Elon for a couple of years...
