Slamming in OD? - JeepForum.com
post #1 of 5 Old 01-18-2014, 04:46 PM Thread Starter
my84_720ST
Slamming in OD?
There's a lady out here in my neck of the woods with a 99 4.7 Limited Quadradrive. She complains that when she is traveling along, with overdrive turned on, when it tries to go into overdrive it "Slams" her back and forth, and wont go. She turns OD off, everything goes back to normal, but she hates the 6mpg.
Any ideas?
my84_720ST is offline
post #2 of 5 Old 01-18-2014, 07:36 PM
bradywgn71
bradywgn71's Avatar
After changing fluid and filters, solenoid pack, speed sensors, pressure sensor, accumulator plate and springs, the only thing that fixed mine was a transmission rebuild. They determined that there was a broken snap ring in the 2nd prime/4th OD clutch and planetary pack.
Mine acted the same way. It actually downshifted to 2nd gear once for a split second while doing 75mph down the freeway. It felt like I had yanked the emergency brake and them immediately released it. The slamming back and forth is the trans shifting into 4th, back to second, into 4th... If I turned off OD after starting the Jeep, it would shift the first 3 gears fine.
2002 WJ Overland - 4.7HO - 231tc - 6" Clayton - 285/75-16 Cooper STT - ProComp 5129 wheels - Kevin's Offroad Belly Skid and Rock Sliders - JKS Track Bar and Disconnects - ProtoFab bumpers
bradywgn71 is offline
post #3 of 5 Old 01-19-2014, 01:08 PM Thread Starter
my84_720ST
Sounds like what she's got going on, I'll be sure to let her know! thanks!
post #4 of 5 Old 01-20-2014, 06:13 AM
Double E
Double E's Avatar
http://www.jeepforum.com/forum/f310/...-long-1148345/
Read this one too.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #5 of 5 Old 01-20-2014, 07:06 AM
bradywgn71
bradywgn71's Avatar
Originally Posted by Double E View Post
That thread is about the 6 cylinder trans. The OP has a V8 so completely different trans.
