SIMPLE Memory Mirror Fix - JeepForum.com
post #1 of 23 Old 05-02-2011, 10:24 AM Thread Starter
mrtoner
Wj SIMPLE Memory Mirror Fix
I have read on the forum where memory mirrors 'forgot' their positions.
The solutions were either to take it apart and clean the contacts, or replace it.
Well, I know in electronics that the best way to keep contacts clean is to have a wiping action, so I tried this:
I put my hand flat with my palm on the mirror, then repeatedly moved the mirror through all 4 maximum positions, up, down, in, and out in a rotating motion.
I did this a month ago to both my mirrors, and they have worked perfectly.
mrtoner is offline
post #2 of 23 Old 05-02-2011, 01:50 PM
bhicks
Awesome. I will try that tonight. My memory mirrors are spastic as hell. I hit the #2 driver button on my Overland after my wife drove it and the mirrors go all over the place. Pisses me off.
____________________________________________
Past-SOLD2000 TJ, 4.0, 231HD,4.5" long armed lift, 4.56's, detroits, 35" KM1's
Past-SOLD 2000 XJ auto 242 4.0 6" Full traction long arm, Dana 44's, MTR Kevlar 35's, 4.88s, Detroits
Present- 2002 WJ Overland, 242HD(going in soon) 4.5" Teraflex/JKS lift, JCR Sliders, TAG bumpers, 33" Muds, 17" JK Moabs ( Future- 2012 JK Rubicon)
bhicks is offline
post #3 of 23 Old 05-02-2011, 01:58 PM
volvite
You didn't take it apart? Just rotated while still together? That's simple enough.
His 99 WJ Limited 4.7
Hers 15 Overland EcoDiesel, ORAII
volvite is offline
post #4 of 23 Old 05-02-2011, 04:20 PM Thread Starter
mrtoner
Wj
Nope - did not take it apart. Rotated the mirror and then cleaned off my handprint......
mrtoner is offline
post #5 of 23 Old 05-02-2011, 04:30 PM
MadMonk
Stupid question for a little clarification - did you move the mirror with your hand or did you use the motor to move it and just apply pressure to the mirror?
'99 WJ Limited 4x4, 4.0L, Patriot Blue Metallic, IRO 3" springs, track bar, and rear sway bar links, Doetsch Tech 8000 shocks, Tenneco steering stabilizer, Carolina Driveline double-cardan front drive shaft.
MadMonk is offline
post #6 of 23 Old 05-02-2011, 08:12 PM Thread Starter
mrtoner
Just move it with your hand; that moves the contacts over the position plate, and repeated movement will clean off the dirty sections...
mrtoner is offline
post #7 of 23 Old 05-02-2011, 08:47 PM
volvite
That will go in my book of things to do. My driver side mirror works just fine, but my passenger mirror will move to memory seat 2 but not one.
volvite is offline
post #8 of 23 Old 05-03-2011, 12:11 PM
leadsled jeep
Ditto. Driver's side on mine has to be adjusted each time we drive it. Resets too low in position.
Interesting, with engine off just put hand palm on mirror and move it up and down and to both sides?
I wonder that it doesnt' mess up some gears or something on it.
Chris
'02 Overland 190k+ miles. 2.5" lift w/springs. All Control Arms upgraded, dual Addco sways.
leadsled jeep is offline
post #9 of 23 Old 05-03-2011, 02:59 PM
1AAdam
X2 i thought that would break it.
Adam
1aauto.com
888-844-3393
1AAdam is offline
post #10 of 23 Old 05-03-2011, 05:50 PM
leadsled jeep
If cleaning the contacts by motion is what is needed, wont it clean by moving it with the electric motor work as well? I do worry about breaking it... haven't tried it yet....
Chris
post #11 of 23 Old 05-03-2011, 05:52 PM
theskier74
i have a problem where my driver side mirror goes down and to the right over the course of the night... i think its not a factory mirror because it doesnt heat up in the winter and has different stickers...would this help?
My Jeep uses the gas your hybrid saves.
Anything your car can do, our Jeeps can do better.
200k+
theskier74 is offline
post #12 of 23 Old 05-03-2011, 07:52 PM
adgjqetuo
adgjqetuo's Avatar
I Actually took mine completly apart cleaned all the contacts and the memory function only fixed itself for 6 months and it was back to losing its position everytime I unlocked the Jeep. I've been dealing with it because taking apart the mirror is a PITA with all of the gears.
I will have to try this.
04 Jeep grand Cherokee Overland - Sold
98 Jeep Grand Cherokee Laredo SE - Sold
adgjqetuo is offline
post #13 of 23 Old 05-03-2011, 07:55 PM
Indy
Indy's Avatar
I just turned the mirror with memory function off. No need to reset the mirror once it's in the right place for me.
I'm the only gay eskimo.
Indy is offline
post #14 of 23 Old 05-03-2011, 09:52 PM
leadsled jeep
I did move the mirror around. It did not seem to restrict my movements of it manually w/o electric motor. Still works. I'll see if it solved my memory situation or not in a few days. Might actually work!
Chris
post #15 of 23 Old 05-05-2011, 11:52 AM Thread Starter
mrtoner
Wj
I guess you could do it with the motors, but would take a long time.
Moving the mirror manually does not seem to bother it; at least I do not hear gear teeth clicking like on GM mirrors.
I did it to both of mine, and so far, has worked like a champ.
Even if I have to do it again in a month or two, it beats disassembly!!
mrtoner is offline
Seat Memory RonWJ2001 WJ Grand Cherokee Forum 8 08-04-2014 03:41 PM
03 WJ Driver side mirror memory position IFLYHWY17WJ WJ Grand Cherokee Forum 2 01-16-2011 06:03 PM
Replacement side mirror (mirror only) AustinCJer WJ Grand Cherokee Forum 3 10-22-2010 09:35 AM
Driver Memory and Mirror position gordon WJ Grand Cherokee Forum 5 08-16-2010 11:06 AM
GC -00 and seat memory problems dj_pirtu WJ Grand Cherokee Forum 1 08-02-2010 09:51 AM
