Sill Cover Molding Removal - JeepForum.com
post #1 of 7 Old 05-07-2013, 10:55 AM Thread Starter
doityourselfMM
doityourselfMM's Avatar
On a 99 WJ Laredo, is there an easy way to remove the Grey Plastic Sill Cover Molding? It is the piece that runs beneath the doors, from wheel well to wheel well. Attached with 9 plastic clips and two screws per side.
I hate to give it a hard yank, if there is an easier way.
doityourselfMM is offline
post #2 of 7 Old 05-07-2013, 12:06 PM
its-me-B
yank it or work a flat head under and pry up...
Do the world a favor, hurt a honda...
Iro 3" lift with pro comp 9000es shocks, adjustable trackbar, led rock lights, all interior lights converted to leds, two 10" kicker comp with Kenwood 600 watt amp
Zombie Outbreak Response Unit #396
its-me-B is offline
post #3 of 7 Old 05-07-2013, 12:57 PM Thread Starter
doityourselfMM
Thanks. The yanking method worked. Already had the new clips on hand. The old ones self destructed.
post #4 of 7 Old 05-07-2013, 01:27 PM
its-me-B
it happens, my passengers can't seem to lift up their feet when getting in or out so mine pop off a couple times a week and one clip thought it was better to just stay in place instead of coming off like the others.
its-me-B is offline
post #5 of 7 Old 05-07-2013, 06:10 PM
Cirruslydakota
I pulled mine off for the rock rail install. They weren't too packed with mud and lucky for me my rockers had no rust at all. The only thing they're good for is trapping dirt and rusting out your rockers so I'd trash them.
Sent from inside my 4.0.
Thorne - 02 WJ Overland
Bear - 99 WJ Laredo
Apollo - 08 Mazdaspeed3
Valentine - 99 XJ Limited
Cirruslydakota is offline
post #6 of 7 Old 09-05-2013, 07:26 AM
Bluerod72
2003 WJ
I've got an 03 grand Cherokee. Is the lower side moldings taped on or clipped on? Would like to remove and possible paint em
Bluerod72 is offline
post #7 of 7 Old 09-05-2013, 07:42 AM
dlundblad
2003 WJ
I believe the molding has 2 screws at each end plus the rectangular clips. Mine were ruined when I took them off. Teamgrandcherokee.com has them. Do a google search I'm their part number and you'll find them cheaper elsewhere.
03 WJ Laredo 4.Sl0w
2" BB, Overland Skids
2nd set of 245/75/16 DuraTracs
dlundblad is offline
