Should I wait it out or buy a new radiator? - JeepForum.com
post #1 of 10 Old 08-17-2013, 09:09 PM Thread Starter
Ridaith
I'm just curious because I took it in the shop the other day and the mechanic seemed pretty serious about replacing it. But I don't have $600 to drop on that and it doesn't even seem like it's leaking at all. (I had to refill the overflow bottle once when I first bought the car, but it still reads full everytime I check it.)
Plus the temperature gauge always reads a little under 210 and if it ever goes over, the fan kicks on without a problem. I have a 1999 Jeep Grand Cherokee Limited with a V8 engine and four-wheel drive. (If that helps any.)
I'd really appreciate any advice, thank you!
Ridaith is offline
post #2 of 10 Old 08-17-2013, 09:45 PM
infob
1993 XJ Cherokee
Plus the temperature gauge always reads a little under 120 and if it ever goes over, the fan kicks on without a problem. I have a 1999 Jeep Grand Cherokee Limited with a V8 engine and four-wheel drive. (If that helps any.)
You mean 220?? Why did he say replace it? If it doesn't leak and you have no cooling issues I would say run it till you have a problem... Perhaps he doesn't like the amount of rust and gunk in it but all he should have recommended was a good flushing for that.... Also 600 is extremely steep for a radiator...... Replace it yourself if you ever need to and save 450 easy or alot more for a real cheap one
infob is offline
post #3 of 10 Old 08-17-2013, 11:28 PM Thread Starter
Ridaith
Oh, my bad. Haha I meant to say 210. But yeah, he said he ran a pressure test and it pissed some coolant but the bottle is still full and it seems like the engine is staying cool. It might just be a slow leak.
If I wait though, will it hurt the engine?
Ridaith is offline
post #4 of 10 Old 08-17-2013, 11:28 PM
oakmckinley
I think he's trying to take you for a ride.
Check it out for yourself, when my TJ rad blew I had fluid leaking out (I could visually see the green discoloration) at the seams.
You would also be able to smell that oh so familiar smell of coolant if you had problems.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #5 of 10 Old 08-17-2013, 11:34 PM
infob
1993 XJ Cherokee
Agreed check it out yourself... If you keep an eye on temp and check the level often if nothing becomes out of the norm then there isn't an issue that would require 600 worth in repairs... No harm will come to the motor unless it overheats and you don't catch it in time and it warps the head or cracks the gasket
infob is offline
post #6 of 10 Old 08-18-2013, 01:16 AM
MGrobe
Man In Black
MGrobe's Avatar
Moved to WJ tech.
-Marc-
Sweet Pea 1998 - XJ
For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area
MGrobe is offline
post #7 of 10 Old 08-18-2013, 05:35 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
$600 for a rad is too much. I think mine was around $400 installed,
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #8 of 10 Old 08-18-2013, 07:55 PM
cubalz
Uh, My radiator was $110.00 shipped to my house. I replaced that, both hoses, T Stat and Anti Freeze replacement in an afternoon for around $200.00
It is easy to do. If you have someone else do it, I am going to need you to surrender your guy card.
2003 Rubicon - 33x12.50x15 GY Duratracs, 15x10 MT Classic Locks, 2" BL, 2" BB, Warn Front Bumper, Garvin ATS Rear Bumper, Body Armor Extreme Rock Rails, Nth Degree Tummy Tucker, Skid Row Engine, LCA and Gas Tank Skid Plates, Teraflex Quick Disco's, Uniden Pro 520xl CB, 3' Firestik Antenna, BW Flat Fender Flares, Tom Woods DS, Currie Rear Adj Arms
cubalz is offline
post #9 of 10 Old 08-18-2013, 08:21 PM
narnwv
narnwv's Avatar
The whole front end of a WJ has to come off, including the A/C condenser to replace the radiator ( by the book)
OP: Pick up a radiator locally for about $200, or PM Kolak for an affordable Mopar replacement. It's possible, although barely, to replace the WJ radiator without pulling the condenser, but it's easiest to do it right and pull the whole front end of the Jeep off. (please see the WJ FAQ)
~Aaron
narnwv is offline
post #10 of 10 Old 08-18-2013, 09:56 PM
infob
1993 XJ Cherokee
Didn't realize what it was for... My mobile doesn't do the profile description thing or I'm just to far behind times to figure out how.... Think my estimate still falls into the price guess I made regardless though since I assumed after further research he would be doing it himself saving the 450 in labor costs
Edit... Now I'm confused somehow my mobile dropped me into the wj section... Hehe I have even less knowledge here than in the Cherokee section
infob is offline
