Should I buy another WJ? - JeepForum.com
post #1 of 23 Old 03-06-2013, 12:11 PM Thread Starter
rlordjr
Current: 2004 Laredo, 110k miles, I6, 4WD Selec-Trac, 2inch lift with OME shocks, Addco swaybar, KOR trackbar bushings, 255/70/17 Wrangler takeoffs
Possible buy: 2004 Columbia Edition, 87.5k miles, V8 HO, 4WD Quad-Trac, factory tow, stock everything
Would obviously swap lift stuff over to new Jeep and sell the I6 one. Now I would have a HO V8 with factory tow, lifted 2".
Probably cost me $1200 between selling mine and buying other.
Worth the trouble?
rlordjr is offline
post #2 of 23 Old 03-06-2013, 02:23 PM
murph0124
2003 WJ
keep the I6
murph0124 is offline
post #3 of 23 Old 03-06-2013, 02:26 PM
Prickett10
I don't see a huge advantage between getting the knew one or keep the one you have, unless you can get it for a ridonkulous price.
Better to be mute than dispute with the ignorant.
Perversion or self exploration isn't the point in this case.In fact there will be no case, no trial by a jury of our peers just fear in the hearts of those we choose. Doing this for the knowledge of our victory, that is how we are different.
Prickett10 is offline
post #4 of 23 Old 03-06-2013, 02:35 PM
jeep04
I think 1200$ and you get 20k less miles a v8 HO, Quadradrive and its a Columbia edition.... i know i would in a heartbeat
04 Jeep wj Limited 4.7 <> 6.5" Iron Rock long arms front & Adjustable lowers on rear <> Bilstein 5100's <> 285/70r17 Goodyear Duratracs <> M/T black classic lock wheels <> Addco swaybars <> Superchips 3875 <> Magnaflow Stainless exhaust <> 2 Kicker comp 12's <> Kenwood head unit.
jeep04 is offline
post #5 of 23 Old 03-06-2013, 02:55 PM Thread Starter
rlordjr
Did I mention the V8 has fog lights? WOW. </sarc>
It's hard to get the mojo up knowing I have to do all the work (whine) and then get the old one sold.
rlordjr is offline
post #6 of 23 Old 03-06-2013, 02:56 PM
PhantomWJ
2003 WJ
Id do it. Power on demand.
PhantomWJ is offline
post #7 of 23 Old 03-06-2013, 04:07 PM
lvngtheJEEPlife
I would do it. Work? yes. Worth it? Totally.
2001 WJ Limited 4.7 Powertech, Quadradrive, 2" BDS lift.
"If you can't get there in a Jeep, You should reconsider going there."
lvngtheJEEPlife is offline
post #8 of 23 Old 03-06-2013, 04:33 PM
snowman91
2003 WJ
Worth the trouble?
Take into consideration all the problems and things you fixes on your current wj vs getting another one and not knowing.what has been done to it.
snowman91 is offline
post #9 of 23 Old 03-06-2013, 05:46 PM
wjstheway03
Deff keep the 4.0 ive seen them go well over 250 k miles. It's a 12 valve straight six its indestructible
wjstheway03 is offline
post #10 of 23 Old 03-06-2013, 05:51 PM
cubalz
agreed. I have both power plants in each of my Jeeps. There is no replacement for displacement. Period.
2003 Rubicon - 33x12.50x15 GY Duratracs, 15x10 MT Classic Locks, 2" BL, 2" BB, Warn Front Bumper, Garvin ATS Rear Bumper, Body Armor Extreme Rock Rails, Nth Degree Tummy Tucker, Skid Row Engine, LCA and Gas Tank Skid Plates, Teraflex Quick Disco's, Uniden Pro 520xl CB, 3' Firestik Antenna, BW Flat Fender Flares, Tom Woods DS, Currie Rear Adj Arms
cubalz is offline
post #11 of 23 Old 03-06-2013, 06:37 PM
lvngtheJEEPlife
Yes, it is arguable that the motor is better. But with proper maintenance the 4.7 is the same. PLUS way more power. And it a columbia edition with less miles. Again, its worth it no questions asked.
post #12 of 23 Old 03-07-2013, 02:14 AM
james_2k
2003 WJ
the 4.7 isn't the same with maintenance, the 4.0 with maintenance is even better still
also extra power is all fine, but wont make any difference when its broken down, 100% power loss right there.
keep the 4. if you have it running nicely, especially if its a dd.
also a big turbo is can be more than a replacement for displacement. never understood that saying.
james_2k is offline
post #13 of 23 Old 03-07-2013, 02:22 AM
chriswj
keep them both and wheel the piss out of the 4.0 keep the 4.7 stock for a dd
2000 Wj in the works taking donations daily!!
chriswj is offline
post #14 of 23 Old 03-07-2013, 05:01 AM
dcorn
+1 As long as you can get the new one for a decent price, I'd definitely do it.
Big turbo on a 4.0? That's supposed to be more reliable than a stock 4.7? Not a chance. Not sure why you guys act like every 4.7L engine explodes on a weekly basis.
I have both engines and both have their quirks, but are also pretty damn reliable. Can't beat that V8 torque.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #15 of 23 Old 03-07-2013, 05:12 AM
james_2k
2003 WJ
no I didn't mean a turbo on the 4.0 i just meant in general (with regards to the 'no replacement for displacement' mantra). but thinking about it, i would love a big turbo on it just for the laughs
im quite happy with the 4.0 performance, it goes as fast as i want it to, generally speaking if it was faster, the suspension and brakes would be the limiting factor around this area with the curvy roads etc.
only slight concession i would make is that i would only think the HO 4.7 would be worth it, far too marginal an upgrade to just the regular 4.7. when you consider all the new potential problems your new car could have. getting rid of a good runner for 35 more hp doesn't seem worth it. you cold get a few mods for the 4.0 to bring it up to 215 im sure. or stroke it for major power
4.7 also weighs a bit more which would slightly negate gains too.
james_2k is offline
