Shocks - JeepForum.com
post #1 of 7 Old 05-06-2012, 01:04 PM Thread Starter
Fiosman
2012 KK Liberty
Wj Shocks
Hey All
I'm doing my 60k mile work on my WJ. While riding in the passenger side, I can see the car is on a slight slant. So Im going to be replacing the front and rear shocks.
1. How do I replace front and rear shocks. I haven't really found anything clear on the internet.
2. Best/cheapest shocks for daily driving?
Thx in advance!
Fiosman is offline
post #2 of 7 Old 05-06-2012, 01:57 PM
imaguy3
Shocks won't affect your ride height. If the truck is slanting it's due to something else. You unbolt the old shocks and bolt the new ones on.. it's pretty self explanatory.
Do some searching on here, there are quite a few threads regarding shocks.
imaguy3 is offline
post #3 of 7 Old 05-06-2012, 02:02 PM
holder14
As far as the slant goes, that is most likely not shock related. The shocks do not do anything for ride height, that would be springs and the spring isolators. If its sagging one way or another I would look into the springs and see what's up.
If you do still want to replace the shock they are easy to remove. Under the hood there is a nut u screw off the top stud of the shock, which will release the top, and on the bottom just unbolt the 2 bolts and take out the shock. For the rear just remove the upper and lower bolts and pull them out.
I also would suggest not going with the cheapest shock u can find. Any decent mono tube will most likely give u the best ride quality, but they are not the only options. And it may be a good time to put on a 2" Bb since you would already be replacing shocks.
2001 Grand Cherokee Laredo 4.0L Patriot Blue (Named ATOM)
Interior: Pioneer DEH-P4900IB Head unit, Eclipse SE6900 6x9 Front speaker, Alpine Type-R 5 1/4 Component Rears, Alpine PDX-F4 Amp.
Exterior: IRO 3 inch Lift, 265/75-R16 General Grabber AT2's, 40' Rigid Industries SR SERIES LED Light Bar, Saguaro 3/4in Shackle mounts, Rola Roof Rack, Kolak Stillen Rotors, EBC green stuff pads, Addco Rear Sway, KOR 1.5" Wheel Spacers
holder14 is offline
post #4 of 7 Old 05-06-2012, 04:34 PM Thread Starter
Fiosman
2012 KK Liberty
Should these be good front and rear replacements?
http://www.ebay.com/itm/4-Shocks-Str...3afb2c&vxp=mtr
Fiosman is offline
post #5 of 7 Old 05-06-2012, 04:44 PM
imaguy3
Link doesn't work.
For inexpensive shocks in other vehicles I've had good luck with Monroe Reflex. Monroe/Rancho are owned by Tenneco... with Rancho being their "offroad" line-up. They do offer monotubes now that are less expensive than the popular Bilsteins...
The Monroe Reflex Monotube part numbers are #911522 ($55 a piece with free shipping on amazon http://www.amazon.com/Monroe-911522-Reflex-Monotube-Absorber/dp/B000EQCVCK/ref=sr_1_1?s=automotive&ie=UTF8&qid=1336344241&sr=1-1 ) for the front and #911523($52 a piece free shipping on amazon http://www.amazon.com/Monroe-911523-Reflex-Monotube-Absorber/dp/B000EQ80RA ) for the rear. They say "for upcountry suspension" but you can use them with a standard suspension as well.
http://catalog.monroe.com/catalogPar...dStatus=ACTIVE
imaguy3 is offline
post #6 of 7 Old 05-06-2012, 04:53 PM
Thomahawk
Go BilsteinHD from Kolak, you Will never regret, contact him at kokak@aol.com he have very good priceing.
Buildthread
Thomahawk is offline
post #7 of 7 Old 05-06-2012, 05:35 PM
imaguy3
The bilsteins are good too... shockwarehouse has them at 75 each...
front http://www.shockwarehouse.com/site/p...Grand-Cherokee
rear http://www.shockwarehouse.com/site/p...Grand-Cherokee
imaguy3 is offline
2.2 shocks? chachalaca WJ Grand Cherokee Forum 7 06-27-2011 11:01 AM
Best shocks GRAND_WJ WJ Grand Cherokee Forum 27 05-19-2011 06:25 PM
shocks gone at 50k? Blue04WJ WJ Grand Cherokee Forum 5 09-11-2010 11:08 AM
what shocks should i go with???? kirbWJ WJ Grand Cherokee Forum 6 03-14-2010 11:26 PM
Help with RE shocks SIU WJ Grand Cherokee Forum 6 03-12-2010 09:40 PM
