shock extension...DIY - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > shock extension...DIY
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 06-03-2011, 06:47 PM   #1
docster
I tried searching, but to no avail. If I missed it, I'm sorry. I have BDS 2 inch springs in my garage right now. However, I just purchased the Jeep a month ago and it has brand new (under 2000 miles) blistiens on all 4 corners. I want to put the springs in this weekend since I will have it apart for some other maintence stuff anyways. Heres what im thinking tho. To do just the springs, and save for new blistiens for the correct lift from Kolak. So I want to keep my current shocks for a couple of months. My thought is that if i can just make a shock extender/spacer for the shock so that i can still drive it without worry of it bottoming out.
something like this. should be able to do with scraps around the house for nothing....
My question is...would this be bad? It shouldnt change the geometry of the shock, so should be fine. Might even be able to just use this for the life of the shocks. It shouldnt limit the travel of suspension at all as in either direction I wouldnt think, would it?
Now I know I should just sell my stock ones and buy Kolaks, but i dont want too. No more money on Jeep upgrades for a while from wife because I just put too much into my pipes on my Ducati...so I have to play nice for now haha.
I have 2 choices then, leave it stock, or put springs in and make shock extenders....what are your thoughts? Safe? Smart?
Sorry for the run on...
2002 WJ Ltd. QD, 4.7L-- 245/65/17. Magnaflow 12256 muffler. --> Mine
2002 Audi A4 Avant 1.8T quattro -- 1.9L Stroker Kit. --> Hers
Stock suspension for sale! http://www.jeepforum.com/forum/f127/oem-wj-suspension-1363286
docster is offline   Reply With Quote
Unread 06-03-2011, 08:28 PM   #2
tsconver
2003 WJ
if made from good quality material and welded properly not sure why it would be bad. What about the rear shocks?
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
My Build Thread
A few goodies
http://s257.photobucket.com/albums/h...umb55839/jeep/
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
http://www.zrxoa.org/
2006 Red Liberty
Wife's ride, pretty stock
http://i257.photobucket.com/albums/h...mage0008-1.jpg
http://www.cnc4x4.org/
http://www.treadlightly.org/
tsconver is offline   Reply With Quote
Unread 06-03-2011, 09:20 PM   #3
MikeeN
2003 WJ
what bilsteins are they?
MikeeN is offline   Reply With Quote
Unread 06-04-2011, 08:15 AM   #4
docster
5100s.
Unread 06-04-2011, 09:10 AM   #5
docster
Won't the same thing work for the rear?
Unread 06-04-2011, 09:28 AM   #6
4Tom
Fitting shock extensions will allow full travel when uncompressed. However full compression of springs will be outside the shocks designed ranged. If you also fitted bum stop extensions it would stop the shock being over compressed.
WJ 2001 3.1TD
http://www.jeepforum.com/forum/f22/2001-wj-3-1td-1252959/
Tom
4Tom is offline   Reply With Quote
Unread 06-04-2011, 09:36 AM   #7
docster
Bump stop Extensions will be done too of course
Unread 06-04-2011, 09:37 AM   #8
MikeeN
2003 WJ
Thought 5100s only came for lifted jeeps?
Unread 06-04-2011, 09:44 AM   #9
Coolhand20th
correct, the minimum they come in is for a lifted jeep 1.5-2" in lift. Otherwise you have to go to a Bilstein HD series shock for stock springs or Up Country springs, they are yellow and blue.
Coolhand20th is offline   Reply With Quote
Unread 06-04-2011, 09:46 AM   #10
MikeeN
2003 WJ
And he's trying to extend them with 2 inch springs? I'm confused I'm running the bilsteins for 2 inch lift at exactly 2.75 inches and its perfect I have the bds springs with 3/4 spacers in there?
Unread 06-04-2011, 09:56 AM   #11
docster
Yes. Yellow and blue. Those must be the hds then because extended they measure the same as stock. Sorry still new to platform. And I'm retarded. Haha. I do have UC springs but they sag and my hub to fender is same as my friends non-UC Laredo.
Unread 06-04-2011, 09:58 AM   #12
MikeeN
2003 WJ
Ok yeah the 5100 are zinc coated so they have a silver coating that's why I was confused haha sorry
Unread 06-04-2011, 10:03 AM   #13
Coolhand20th
how many miles are on it? And are you sure it's the springs and not the insulators? While we all know springs do sag after time, but many overlook the insulators as well. Yeah I know some may say I harp about it, but after seeing what Billzcat went through and seeing what my own look like right now. Those damn bottom ones take the brunt of the abuse we put on our Jeeps.
http://www.jeepforum.com/forum/f310/...hread-1154164/
Unread 06-04-2011, 10:39 AM   #14
4Tom
shocks will be working within designed range so should last.
WJ 2001 3.1TD
Tom
Unread 06-04-2011, 10:45 AM   #15
docster
The isolators are new too. Only about 5k on them. The jeep has 98k on it
