shimmy when cruising - JeepForum.com
post #1 of 12 Old 11-06-2013, 07:57 PM Thread Starter
toates89
1989 XJ Cherokee
Just replaced all 4 tie rods in my 99. This fixed the clunk, but I am still getting a shimmy over 55 when cruising. Its worst around 70mph. the second i accelerate it goes away.
Any ideas at what i should look at?
toates89 is offline
post #2 of 12 Old 11-08-2013, 10:22 PM
gotjeepzj
If the shimmy is in the steering wheel check your steering stabilizer.
gotjeepzj is offline
post #3 of 12 Old 11-09-2013, 08:44 AM
Tumbleweed1954
Rotate your tires. If the problem goes away then it's a tire issue. Also check the ball joints. If you ARE NOT feeling the shaking in the steering wheel then check your u-joints.
Tumbleweed1954 is offline
post #4 of 12 Old 11-09-2013, 09:17 AM
Highschool_WJ
This only masks a much bigger problem, check the ball joints if you can feel the wobble in the steering wheel, or u joints if you can't. Then if those are good check the bushings on your upper and lower control arms
,,,soooo I graduated in 2013...
Highschool_WJ is offline
post #5 of 12 Old 11-10-2013, 11:10 AM
gotjeepzj
If its a new stabilizer already then yes it would just be masking. However on my dub with 140K the shimmy went away when I swapped the stock factory stabilizer for a direct replacement new one. The one that was on there was the original and had 0 resistance left and wasn't doing its job. If the shimmy is in your butt, check u joints.
post #6 of 12 Old 11-10-2013, 04:03 PM
Highschool_WJ
No, I've tested the theory on steering stabilizer, put a new one on and it cover up slightly worn ball joints. Wobble came back so I fixed ball joints. Put old steering stabilizer back on (it would fall on itself when set on its end) no wobble. Drove it like for a while and all I noticed was a some bump steer. Put new one back on and that went away as well.
I even contacted the dealer about this issue when my wobble came back. Steering stabilizers only mask other problems. It will fix it for a while but it will come back.
post #7 of 12 Old 11-11-2013, 03:17 PM
Tumbleweed1954
I may be wrong but I think the steering stabilizer is for off-road. It's like a shock absorber so if you hit a big rock or something the steering wheel doesn't fly out of your hand.
post #8 of 12 Old 11-11-2013, 05:47 PM
Highschool_WJ
That is correct, but is also for on road use, to keep bumps in the road from tossing the vehicle back and forth
post #9 of 12 Old 11-12-2013, 07:08 AM Thread Starter
toates89
1989 XJ Cherokee
The shimmy is felt in the seats. I think the rear bushing int he A arm above the rear axles is on its way out. I was told during inspection that the ball joints felt fine. I wish i asked this question earlier. snow just feel so i will deal with it until spring. i think i ll try and pull the front driveshaft and see if it improves.
Thanks
toates89 is offline
post #10 of 12 Old 11-13-2013, 06:52 AM
gotjeepzj
Rule of thumb is if you feel it in your seats, its in the rear. On a side note, I just solved my shimmy by rotating the tires. I took my left front and swapped with right rear. This wasn't recommended by anyone. I just got to looking at the tires and the left front had more edge wear from turning so I swapped it with right rear which had more of a square edge.
post #11 of 12 Old 11-13-2013, 02:23 PM Thread Starter
toates89
1989 XJ Cherokee
the rear tires make it worse
toates89 is offline
post #12 of 12 Old 02-10-2014, 09:02 AM Thread Starter
toates89
1989 XJ Cherokee
Its been a while but is has been resolved. I replaced all three tierods. and the shimmy was still there. aligned it. still there. then i drove all winter in all time 4x4 and it must of loosened something up because it started to go away.
then i had my tires balanced and rotated(the bad tierods caused some cupping)
Still need to do rear a arm
Thanks all
toates89 is offline
