Shimmy between 46-52mph - JeepForum.com
 1Likes
  • 1 Post By bjh0616
post #1 of 6 Old 08-21-2017, 04:22 PM Thread Starter
bjh0616
I have this shimmy that physically moves the steering wheel in my hand only between 46-52mph. When Im accelerating it is worse, but I can even feel it when completely off the throttle and brakes coming to a stop through this speed range. It is not as bad as death wobble, but I am afraid of hitting any bumps during this speed that might push it to start death wobble. So far I have replaced the drag link assembly, installed KOR super hard bushings in my JKS adj trackbar and just had the front tires road force balanced. I still feel like it has to be a tire issue, when they gave it back to me after road force balancing I noticed it had a good deal of weights on the inside and outside of the wheels, much more than when I brought it to them. I asked the shop to check the ball joints when they had the wheels off and they said it looked good. Any other suggestions?
bjh0616 is offline
post #2 of 6 Old 08-21-2017, 06:43 PM
skipperau
Wheel bearings are a possible candidate here, I personally think you're on the right track thinking it's tyre related, but seeing you've just had them rebalanced I'd look at the wheel bearings. Tie rod ends too.
skipperau is online now
post #3 of 6 Old 08-21-2017, 07:38 PM
gsxr800
I have that shimmy between 42-47 mph. Not there before. Not there after. It's so precise it's amazing.
02 Grand Cherokee 4.0 w/IRO 3" lift, Procomp ES9000, Adj track bar, 17" JK Moab w/GY Wrangler STR
gsxr800 is offline
post #4 of 6 Old 08-21-2017, 08:07 PM Thread Starter
bjh0616
Yes, mine is definitely very precise in this speed range. What's highly annoying about it is my commute to work is mainly a 45mph zone with heavy traffic so I spend 90% of my drive time in this speed range.
gsxr800 likes this.
bjh0616 is offline
post #5 of 6 Old 08-23-2017, 09:31 AM Thread Starter
bjh0616
Before I took it to have the tires re balanced I had the air pressure at 32 psi, I noticed that they had them all at 39 psi after I got it back. I have 265 70 18 General grabber at2's, I am going to lower it back down to 30-32 psi and see if that makes a difference. What is the correct pressure it should be?
bjh0616 is offline
post #6 of 6 Old 08-23-2017, 09:36 AM
skipperau
Look at the tyres load information on the sidewall. I run mine at around 75% of max pressure. In the case of my Falkens, max load rating is at 51psi, I run them at 46 and they are great, if I run them at the placard pressure they squirm and handle poorly.
