Security system - JeepForum.com
post #1 of 14 Old 07-24-2013, 09:13 PM Thread Starter
beachguard
Wj Security system
I want to disable the stock security system so I can install an aftermarket system. Does anyone have any tips. I'm installing a viper VSS5000
beachguard is offline
post #2 of 14 Old 07-25-2013, 01:34 AM
Thomahawk
When i installed my Viper alarm, i didnt have to disable the factory alarm, the viper controls it, so there Are kinda doubled alarmed.
Buildthread
Thomahawk is offline
post #3 of 14 Old 07-25-2013, 05:56 AM Thread Starter
beachguard
What about the remote start. What do you have to get to trick the car into thinking there is a key in the ignition on startup
post #4 of 14 Old 07-25-2013, 06:47 AM
rdkendrick
2003 WJ
I believe, there are chips (from inside the key) that one can buy, program, and stick close to the SKIM antenna.
Sent from my iPad using Forum Runner
rdkendrick is offline
post #5 of 14 Old 07-25-2013, 07:51 AM
Thomahawk
Skim bypass module, all info you will need in my viper alarm remote start thread, search and you will find.
What it does when hooked up to the bus wire in the Jeep. While programing it, it copy the key skim signal, next tine need remote start, bypass module will send out the the copied signal, BAM!
Buildthread
post #6 of 14 Old 07-25-2013, 12:27 PM Thread Starter
beachguard
ok I'll take a look at it
post #7 of 14 Old 07-25-2013, 02:47 PM Thread Starter
beachguard
I looked through all you posts and I couldnt find it. can you send me a link
post #8 of 14 Old 07-25-2013, 02:49 PM Thread Starter
beachguard
just found it. thanks
post #9 of 14 Old 07-25-2013, 06:00 PM
Thomahawk
Cool
Buildthread
post #10 of 14 Old 07-25-2013, 07:33 PM Thread Starter
beachguard
Cool
Which idatalink model did you use?
post #11 of 14 Old 07-26-2013, 04:56 AM
Thomahawk
I dont remember, but That info should be in my alarm thread.
Also if you ho on idatalink website, they will show which module correct for your Vehicle.
Buildthread
post #12 of 14 Old 07-26-2013, 04:58 PM Thread Starter
beachguard
well they have one that just handels the stock security system and another that does that and door locks. do i need the one that does both or can i just wire the viper into the door lock wires
post #13 of 14 Old 07-26-2013, 05:51 PM
Thomahawk
Here you Go,,,,
Buildthread
post #14 of 14 Old 08-06-2013, 06:03 PM Thread Starter
beachguard
Here you Go,,,,
So I finally finished the alarm instal. The Flash logic box works great you just have to pay really close attention to the wire diagram. If you mess up one wire it wont work at all. But it works great if everything is right. Now I just have to put the car back together and get ready for the next project.
