Security reset - JeepForum.com
post #1 of 9 Old 06-17-2010, 11:26 AM Thread Starter
ColdCase
My Reality Check Bounced
ColdCase's Avatar
2011 WK
Security reset
Apparently my 2000Jeep has sat idle with a dead battery so long the security system has disabled (acts like bad CKS). How do I reset. There is no security option on this Jeep.
2000 grand cherokee larado I6
ColdCase is offline
post #2 of 9 Old 06-17-2010, 12:28 PM Thread Starter
ColdCase
ColdCase's Avatar
2011 WK
Spouse was in a panic so I posted this before taking the time to search. It looks like a sentry key problem, correct me if I'm wrong but the only way to fix it is a tow into dealer, then tow it back to the tranny shop. Not a good day. Hope its not a PCM.
ColdCase is offline
post #3 of 9 Old 06-17-2010, 12:56 PM
nlynd1978
2006 XK Commander
If you have no security on the jeep how did it reset?
06 Commander Limited,4.7,130k
01 GC Limited,QD-II,4.0,236k-sold
99 GC Laredo,QT-II,4.7,96k-Sold
nlynd1978 is offline
post #4 of 9 Old 06-17-2010, 12:58 PM Thread Starter
ColdCase
ColdCase's Avatar
2011 WK
Its the sentry key system (chip on the key) that all 1998+ Chrysler vehicles seem to have, not an optional security system
ColdCase is offline
post #5 of 9 Old 06-17-2010, 01:01 PM
nlynd1978
2006 XK Commander
so you have transponder keys. The pcm is encoded with you keys signal. dead battery should not wipe it. If you jeep wont start after leaving it dead for a month you have other problems. I pulled mine out of my friends garage it sat there with a dead battery for 6 years. key still works.
post #6 of 9 Old 06-17-2010, 01:16 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
You should know of the SKIS system is disabling your Jeep because the amber security light will lightup on the dash. But it allows your Jeep to start for a couple seconds before automatically turning the engine off. So if the engine isn't even starting, it isn't the SKIS system. If the battery is completely toast, start by replacing it with a known good battery (not just jumping it or trying to charge it). The electronics (computer) are very finicky if they don't get enough power.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #7 of 9 Old 06-17-2010, 02:40 PM Thread Starter
ColdCase
ColdCase's Avatar
2011 WK
Yes I did all that prior to shipping it off to the tranny shop. It had classic CKS symptom, start for a few seconds then die, no codes. Gauges pass test but stay pegged to left. Tried a relatively new battery from another vehicle. Fuel rail pressure OK. Since the CKS was probably the problem, (really a PITA to get at without loosening the trans mounts on this Jeep) and they were probably going to pull the tranny anyway I took a chance and just had the tranny shop change the sensor. The red sentry key light did not register with me, thought it was either bulb check or seatbelt indicator... I dunno my mistake.
Everyone here was saying CKS but the tranny shop noticed the sentry key indicator right off. Tried second key but no joy, its being towed to dealer... could be simple as corrupted sentry key memory or worse, a PCM failure.
Getting this vehicle back on the road has been quite an adventure.
Thanks for all the help. I hope I can afford the electricity to post the results after the dealer gets through with it.
ColdCase is offline
post #8 of 9 Old 06-17-2010, 09:04 PM
nlynd1978
2006 XK Commander
Actualy sounds like a skis issue. When it starts is the skis light on, or does it come on when the vehicle die?
post #9 of 9 Old 06-18-2010, 03:19 PM Thread Starter
ColdCase
ColdCase's Avatar
2011 WK
This turned out to be a bad PCM. Dealer could not program it to clear sentry thing. Patching in a test PCM worked well for them until the CKS showed another failure. Dealer estimate is $1100 to repair PCM and CKS, like $700 for the Mopar PCM, another $140 for the CKS and $300 labor, which includes the troubleshooting. My choice is to have it towed back to the house or have the dealer try to fix it. Oh well.
I wonder if the Mopar PCM is a quality rebuilt, or the same quality as the $150 ones on ebay.
ColdCase is offline
possible to reset the TCM on a WJ? mailforjon ZJ Grand Cherokee Forum 1 10-09-2008 04:48 PM
How to reset the ECU????? sethfosho ZJ Grand Cherokee Forum 3 01-17-2008 01:35 PM
IAC reset help Yardman Harry ZJ Grand Cherokee Forum 3 09-30-2007 05:29 PM
How to reset ECU mdevinc ZJ Grand Cherokee Forum 8 06-06-2005 06:59 PM
Limited Setnry Security reset 4cherokee WJ Grand Cherokee Forum 2 10-21-2003 11:59 AM
