Seat is stuck in my Overland!! - JeepForum.com
post #1 of 8 Old 11-01-2011, 06:00 PM Thread Starter
bhicks
So my wife calls me a little while ago and tells me the seat is stuck all the way back and she can't reach the peddles. I drove down and traded cars with her. The seat will move up and down and tilt back and forth but will not move in and out along the track. The motor kicks on but only moves the seat about a 1/2" before it stops. If I leave the botton on I can hear the motor trying to move the seat but it's not budging. I checked the track and there is nothing blocking it. The track and all frame pieces seem in tact with no breaks or damage. The seat is very firm which makes me feel like it's not mechanical but more electrical. Maybe the motor is going out. Any help or personal experience with this issue would be greatly appreciated. I will be driving the car to work tomorrow and then will remove the seat when I get home. Hopefully there will be some responses to this before then so I'm not just guessing on the problem.
____________________________________________
Past-SOLD2000 TJ, 4.0, 231HD,4.5" long armed lift, 4.56's, detroits, 35" KM1's
Past-SOLD 2000 XJ auto 242 4.0 6" Full traction long arm, Dana 44's, MTR Kevlar 35's, 4.88s, Detroits
Present- 2002 WJ Overland, 242HD(going in soon) 4.5" Teraflex/JKS lift, JCR Sliders, TAG bumpers, 33" Muds, 17" JK Moabs ( Future- 2012 JK Rubicon)
bhicks is offline
post #2 of 8 Old 11-01-2011, 09:11 PM Thread Starter
bhicks
I decided to go ahead and yank the seat tonight. I noticed that there was a little plastic stop inside the track that had basically disinigrated. It's held in place by a metal nut on the outside of the track and the stop has plastic threads. What a STUPID design. I also can not find out how to get inside the track to replace the piece. So right now I cramed a bolt into the hole that's basically acting as a stop and is held in place with JB weld. Horrible fix to the problem but at least the seat is moving back and forth again. Now I need to find a new track and possibly entire frame from the Junkyard or just grab an entire seat out of a gray interior Overland. If anyone knows of an Overland being parted out, please let me know.
bhicks is offline
post #3 of 8 Old 11-01-2011, 10:14 PM
kerno
I don't think the cheezy plastic parts are available from the dealer and the entire seat track is blindingly expensive. There are lots of seat tracks for sale on eBay, so you have a couple choices. First, right seat tracks are selling for less than lefts, because the lefts fail first. The advantage of buying a right track is that it will have less wear.
You can switch the mounting feet on the tracks very easily. One big Torx bolt and you are done. So, if you have a dead left track, buy a right and swap the lower part of your dead left track (with the holes that bolt to the body) to make a left out of it.
Memory seats are different, so you need to buy a memory track for your Overland OR you can buy a basic power track and swap the worn out parts.
kerno is offline
post #4 of 8 Old 11-01-2011, 10:57 PM
Upside
Have a picture of the part you need? My local Pick Your Part just got a WJ in that has power seats. I may go there and swipe the rear sway bar linkage.
Upside is offline
post #5 of 8 Old 11-02-2011, 08:42 AM Thread Starter
bhicks
The previous poster talked about the one big Torque bolt that holds the track on. That's what broke. The main torque bolt (one on each side of the track) threads into a plastic sleeve. It's the plastic sleeve the fell apart. So the track is only being held together by the bolt on the other side. This causes the seat to move down the track in a jurky manner since the bolt/stop on the other side isn't keeping everything lined up properly. I need the entire track assembly from a WJ with the memory seats. If you find something grab it. I can drive down to you and pick it up later.
bhicks is offline
post #6 of 8 Old 11-02-2011, 03:04 PM
Upside
OK I'll see if it's still there. When I looked at it a couple days ago someone had swiped the passenger's side seat and the drive cables from the motors. My dad had one of those break on his Overland and had a speedo shop make a new one for $10 since you can't buy just the cable.
Upside is offline
post #7 of 8 Old 11-02-2011, 07:55 PM Thread Starter
bhicks
PM Sent
bhicks is offline
post #8 of 8 Old 11-02-2011, 07:59 PM Thread Starter
bhicks
This gives me an idea. If "upside" doesn't find one at the junkyard then I might just swap the tracks from the passenger side to the driver side. My passenger seat works great. That way my driver seat is fixed and the passenger seat has the issue. I can get the seat set in and out to a comfortable spot for both my wife and I and then just disconnect the motor for the in and out. The up and down and tilt will still work. This gives me a fix with no money out of pocket. It's ghetto, but should work and leave me money for mods and not repairs.
bhicks is offline
another heated seat question 02 Overland RAM1958 WJ Grand Cherokee Forum 3 01-25-2011 10:08 AM
Power seat is stuck SP04SE WJ Grand Cherokee Forum 1 11-14-2010 03:36 PM
Looking at an Overland-help! SPDK1LZ WJ Grand Cherokee Forum 23 09-14-2010 02:32 PM
is this a overland or not jefflacy WJ Grand Cherokee Forum 10 03-27-2010 05:55 AM
The new Overland Camster WJ Grand Cherokee Forum 6 05-13-2002 04:46 AM
