Seat Memory - JeepForum.com
post #1 of 9 Old 02-10-2011, 04:43 PM Thread Starter
RonWJ2001
Seat Memory
2001 WJ Limited
Im unable to program my seat memory anymore. The 1 button when pushed does nothing, the 2 button when pushed shows dr_1 on the radio, the set button when pushed shows dr_2 on the radio. The set button light never lights up anymore. I havent pulled the door panel off yet to see if the connector is loose or maybe inproperly install last time the panel was off. Does anyone have any ideas before i start taking things apart?
thanks
RonWJ2001 is offline
post #2 of 9 Old 02-11-2011, 02:19 PM Thread Starter
RonWJ2001
I've now discovered that my seat memory buttons function perfectly when the key is not in the on/acc position (ie dont put the key in). The manual states to place it in the on position when setting seat memory. When in the on/acc position I have the problem stated above. Is this normal?
post #3 of 9 Old 02-11-2011, 03:33 PM
Mr_Grumpy
Sorry dont know but i have always done this without key in or when actually running engine ( no reasosn just ends up that way lol)
Mr_Grumpy is offline
post #4 of 9 Old 03-09-2012, 12:48 AM
CowboyPilot
I have precisely the same issue. Are you able to program with the key out using the rest of the factory instructions?
CowboyPilot is offline
post #5 of 9 Old 03-09-2012, 06:22 AM
shockracer
Same problem here, i said heck with it and just manually adjust every time.
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #6 of 9 Old 07-28-2014, 10:37 PM
Krwlnrx
Anyone ever find a conclusion to this issue? My 00 WJ will not retain the settings I adjust to. Always goes back to whatever the PO set, which as far as I can tell, is gansta lean.
2000 WJ Limited in arrest me red. :)
4.7L Quadra-Drive.
"You can go fast, but I can go anywhere."
Krwlnrx is offline
post #7 of 9 Old 07-31-2014, 09:09 AM
pdpunome
I had the same problem before and turned out to be the module under the driver seat. Dont know if that will solve your issue, but I do have a spare up for grabs.
2000 4.0 Selec Trac
pdpunome is offline
post #8 of 9 Old 08-01-2014, 10:31 AM
Krwlnrx
Pm sent..
4.7L Quadra-Drive.
Krwlnrx is offline
post #9 of 9 Old 08-04-2014, 03:41 PM
pdpunome
Originally Posted by Krwlnrx View Post
Pm sent..
Reply had been sent
2000 4.0 Selec Trac
pdpunome is offline
Memory Seat Install... Is it Possible?. blazepsi WJ Grand Cherokee Forum 9 11-23-2011 05:35 PM
" Memory Seat Disabled " ??? cmelde WJ Grand Cherokee Forum 3 11-15-2010 05:18 PM
GC -00 and seat memory problems dj_pirtu WJ Grand Cherokee Forum 1 08-02-2010 09:51 AM
WJ memory seats / seat belt fastened W3MOT WJ Grand Cherokee Forum 0 05-27-2010 11:46 AM
Seat memory problem in GC 2.7 CRD Limited durone WJ Grand Cherokee Forum 0 04-05-2003 04:14 AM
