Sand Paddles - JeepForum.com
post #1 of 15 Old 05-28-2013, 11:13 AM Thread Starter
Roger005
Sand Paddles
What do you guys think of running 32" sand paddles on a V8 WJ? Going to be making a trip to the sand dunes next month.
Roger005 is offline
post #2 of 15 Old 05-28-2013, 11:36 AM
ZB_WJ
Seen an xj on tractor tires but not a wj on paddles
opcorn:
I think we all just need a beer. :cheers2: (courtesy of ChrisHager)
This forum is a double edge blade, it's saved me thousands in repairs and cost me thousands in mods
ZB_WJ is offline
post #3 of 15 Old 05-28-2013, 11:57 AM
silentbob21
I've never seen it either, but if you can clear em and get it there then I say give it a shot!
opcorn:
2004 WJ SE 4.0L I6, NV242, IRO 6.5 LAs D44a Spartan locked, 4.88s, BFG KM2s 35/12.5/15
silentbob21 is offline
post #4 of 15 Old 05-28-2013, 01:24 PM Thread Starter
Roger005
Think the axle will be ok?
Roger005 is offline
post #5 of 15 Old 05-28-2013, 01:38 PM
fast540
Take pics
fast540 is offline
post #6 of 15 Old 05-28-2013, 07:22 PM Thread Starter
Roger005
I am really anxious to try this out. I managed to pick up a pair of free paddles from a family member and I was wondering what everyone's thoughts were? Think the dana 44a can handle it?
Thanks guys
Roger005 is offline
post #7 of 15 Old 06-05-2013, 03:45 PM Thread Starter
Roger005
Well I ordered some 15x14 Black Rock steel wheels with 4" bs today and some 1.5" wheel spacers. I hope this turns out as it would be pretty unique.
Roger005 is offline
post #8 of 15 Old 06-05-2013, 03:52 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
I have a feeling your transfer case and vari-locks are not going to like that setup at all. Also, with the equivalent of 2.5" of backspacing, your bearings are going to crap out very very quickly.
It sure will be interesting though! lol Take lots of pics and let us know how it goes.
~James
ezflip is online now
post #9 of 15 Old 06-05-2013, 03:55 PM Thread Starter
Roger005
Ill only be using them while at the dunes. Hopefully it will be ok. What are you thinking about the t case and vari-locks?
Roger005 is offline
post #10 of 15 Old 06-05-2013, 04:00 PM Thread Starter
Roger005
Going to be in Low lock and have the tires on all 4 corners aired to the same height. I can see the wheel bearing issue though..but hopefully they will be ok for a week trip lol
Roger005 is offline
post #11 of 15 Old 06-05-2013, 04:49 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
What are you putting on the front?
Have you ever been to Silver Lake?
A V8 WJ with aired-down, street tires will blast around those dunes no problem.
Wheelin98TJ is offline
post #12 of 15 Old 06-05-2013, 06:14 PM
ezflip
ezflip's Avatar
2011 JK Wrangler
If youre in low range, the tc should be okay, but the axle...youre going to be throwing a lot of sand rather than riding on top of it. Thats going to be a lot of weight being thrown around and therefor, a lot of force being applied to the axle and diff. I wouldn't be surprised if you at least break a half shaft if not worse.
And what wheelin98tj said, really any WJ on aired down street tires does just fine at silver lake. I was up there in my 2000 4.slo on the stock wrangler SRAs and aired down properly, I did just fine.
~James
post #13 of 15 Old 06-06-2013, 06:59 PM Thread Starter
Roger005
I have been going there for about 12 years now. I have had a different WJ V8 out there before with a 3" IRO and it did good. I was just wanting to try something different but I decided to hold off for now because I dont want any issues for my week long trip.
Roger005 is offline
post #14 of 15 Old 06-06-2013, 08:50 PM
C101Commando
I've always found the dunes to be pretty easy on axles, just really hard on engines. Should be way easier on the axles than rock crawling, in sand there's enough slippage to pretty much eliminate any shock loading.. I'd try it..
03 WJ, 4.7 Limited
C101Commando is offline
post #15 of 15 Old 06-07-2013, 12:54 PM
Wheelin98TJ
JEEP FREAK
Sand can provide excellent traction at any moment.
Some of the guys that run the sand drags often will tell you they hook better on sand than they do pavement.
