Rust question - JeepForum.com
post #1 of 4 Old 07-05-2013, 06:53 PM Thread Starter
elcorvino
2003 WJ
Back home on vacation and my buddy who works on cars is also on vacation. Go figure.
Anywho, cut out all the rust. A fellow jeeper said I should leave the foam out... Any other suggestions on how to treat this before I get a new piece welded in?
Just hit it with primer to prevent further rusting.
elcorvino is offline
post #2 of 4 Old 07-05-2013, 07:35 PM
cykaaro
I'd have sealed it with por15. Used it on my XJ when we repaired the floors. WOrked great.
The beatings will continue until attitudes improve!
HID Quad bi-xenon + foglight retrofit
http://www.hidplanet.com/forums/showthread.php?44572-Jeep-2000-Grand-Cherokee-WJ
cykaaro is offline
post #3 of 4 Old 07-06-2013, 07:35 PM
Turbozcs2003
weld it up and finish.
Then pull the black plastic trim on rocker and flood the rockers with Fluid film.
http://www.amazon.com/Fluid-Film-Spr...rds=fluid+film
http://www.fluid-film.com/
Turbozcs2003 is offline
post #4 of 4 Old 07-06-2013, 08:52 PM Thread Starter
elcorvino
2003 WJ
That's what I figured. Hit the inside with a small Dremel ball and get any more rust out and plaster it with 6 coats of primer.
