running diesel 15-40 in a 4.7 - JeepForum.com
post #1 of 8 Old 08-06-2011, 04:52 PM Thread Starter
marteld
i recently had the oil filter on my 4.7 loosen off out in the middle of nowwhere and had to use 15-40 diesel oil that a very nice trucker had in his rig i was wondering if it would be harmful to my engine i ran it for about 250k before i changed it
marteld is offline
post #2 of 8 Old 08-06-2011, 06:23 PM
rm2001wj
rm2001wj's Avatar
That's only about 150 miles. It won't hurt the engine.
rm2001wj is offline
post #3 of 8 Old 08-06-2011, 06:47 PM
4Tom
The grade is thicker than normal but you be ok.
In fact I know of some that run diesel oil in petrol engine because of it's cleaning agents.
WJ 2001 3.1TD
Tom
4Tom is offline
post #4 of 8 Old 08-06-2011, 09:43 PM
KayCeeJeep
No worries. I'm running it right now in my 4.0, probably not a good choice for the 4.7 but it wouldn't hurt it a bit being summer.
KayCeeJeep is offline
post #5 of 8 Old 08-06-2011, 10:34 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
The cam followers are pretty sensitive to oil weight. Keep an ear out for knocking.
ratmonkey is offline
post #6 of 8 Old 08-06-2011, 10:46 PM
MGDWJ
I ran royal purple 15w-40 HD in mine for 3000-4000 miles. No knocking. Theoretically with the extra detergents that diesel motor oil has it could cause oil leaks. If a build up had it sealed off and the high detergent oil broke down the build up.
MGDWJ is offline
post #7 of 8 Old 08-06-2011, 11:30 PM
Kramer H
Built and Supercharged 47
Kramer H's Avatar
Ratmonkey is correct, the cam followers and hydraulic lash adjusters do not like oil that thick, you will develop a tick from either or both heads due to lack of oiling. Bearing clearances are set to run a specific weight and viscosity oil, start changing and mixing and what not, that's how knocks happen. The number 8rod bearing being most common as I have found in the 4.7s. It's fine to limp you home, but I would never run it 5k every oil change. I run motorcrafts semi synthetic blend of 5w30, works great.
Built Beater 01 WJ
Swapped, SUPERCHARGED Locked, Lifted and Long Armed.
02 Cummins. It has a smoking problem, And it wont quit.
K8 GSXR 1000- Racefit,Comp Werks,Puig,Woodcraft,B2 Industries,55W HID'S, R&G Engineering, Two brothers, ASV, DDM, "The pantie dropper"
Kramer H is offline
post #8 of 8 Old 08-06-2011, 11:30 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
It could also cause a collapsed follower from crud getting into it. Killed my friends wj that way.
2.7 Diesel not starting terryb WJ Grand Cherokee Forum 4 06-11-2011 10:39 AM
Pause like a Diesel, then start? zBeeble WJ Grand Cherokee Forum 9 04-02-2011 05:34 PM
Smell of diesel in cabin dsl55 WJ Grand Cherokee Forum 12 12-04-2010 07:54 AM
My 4.0 sounds like a diesel Rushkiboy WJ Grand Cherokee Forum 22 10-27-2010 11:12 AM
Diesel 2.7 GC Glion WJ Grand Cherokee Forum 16 10-07-2010 05:41 PM
