Rubbing/Binding sounds while making sharp turns on payment. - JeepForum.com
post #1 of 15 Old 05-02-2012, 11:49 AM Thread Starter
VA-WJ
Wj Rubbing/Binding sounds while making sharp turns on payment.
As I pulled though a sharp left hand turn at the drive though last night, it was as if the wheels were having the break applied as I was trying to move forward. A rubbing sound came from the front wheel/axle area. The second I straightened out the wheel from the sharp turn, everything freed up. Almost like a binding / grabbing feeling. When I turned out of the parking lot (another sharp right turn) it grabbed / rubbed for a second time. When I straightened up the wheel, everything went back to normal.
Do you guys think this is a binding differential? Should I change front and rear differential fluids? Do I have something wearing out?
I am slowly approaching my service change interval for the front and rear differential fluid. Could my binding issue be related to my fluids needing to be changed?
VA-WJ is offline
post #2 of 15 Old 05-02-2012, 12:11 PM
Planetcat
2010 WK
If it's a limited with quadradrive, it could be the all-time 4wd kicking in due to the difference in wheel speed when turning tightly. Mine does this constantly, even though I don't have QD but have a detroit true trac in front. It never hurts to swap your diff fluid with factory recommended fluids and add some new OEM friction modifier.
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #3 of 15 Old 05-02-2012, 02:36 PM Thread Starter
VA-WJ
Planetcat - I did forget to mention I have a 4.7 Limited with Quadradrive full time 4wheel drive with 154,000 miles on the clock.
I know that my father in law had synthetic diff fluid added (unknown vendor) and I see that Friction Modifier was added according to the service records that were provided to me at the time I purchased the vehicle.
I have seen posts about Redline diff fluid having the FM already added and I have also seen posts where people just run OEM Fluids only in their differentials.
I have about 8,000 miles before the change is due, but I didn't know if you guys saw any value add from changing fluids early and if you would recommend going with a different fluid for the differentials?
Thanks!
VA-WJ is offline
post #4 of 15 Old 05-02-2012, 02:44 PM
cuttysark
VA-WJ: Are you referring to the service interval denoted by the dealer when you say youre 8k out from change? if so, I believe they ask for it to be changed every 60K, I have read many people say a minimum of 30K, for our transfer cases (I dont have Q-Drive but have the same case - 247 just different axles), I am heeding everyones warning to be on the safe side, Im going to do mine every 30,000 KM. In fact I just did it.
I would definately change yours asap, why not? It's only $17/qt from dealer and AFAIK no friction modifier is needed. NV247/249 Mopar Fluid (light honey in color). Dealer only.
EDIT: HAHA! when I heard binding I immediately thought transfer case, you were talking about differentials..! Definately check your transfer case first, not your differentials! Can almost guarantee its that. I would change fluid, warm it up and do some figure 8's in a parking lot to see if it helped.
If not, you may need it to be serviced.
cuttysark is offline
post #5 of 15 Old 05-02-2012, 04:38 PM
imaguy3
VA-WJ: It's your front diff. When I get close to my service interval sometimes I'll get a little binding, also if I do a super tight turn and it's getting good traction it will bind a little. It's normal... Just make sure when you service the diff's you use the correct friction modifier.
Personally I just buy the friction modifier from the dealer and the regular 75w-140 synthetic diff. fluid from any parts store...
http://wjjeeps.com/service/maintenance_wj.htm#FAXLE
After I change it I go into the desert by my house and do tight figure 8's to get it all worked in. If you haven't done a lot of tight turns/offroading, it probably wouldn't hurt to find a gravel/dirt lot and do some tight figure 8's anyway. There should be no binding on that type of surface b/c it will allow the wheels to travel at different speeds easier.
imaguy3 is offline
post #6 of 15 Old 05-02-2012, 04:43 PM
imaguy3
It's not... it's the front diff., what he described is normal
imaguy3 is offline
post #7 of 15 Old 05-02-2012, 04:47 PM
99WJdan
Mine does it too, its normal for quadradive systems. Like Planetcat said, it thinks the wheel is slipping and 4wd kicks in. Happens all the time when turning into/out of tight parking spaces.
99' WJ 4.7, 3.5" lift, Bilsteins, JKS goodies, 32" Guard Dogs on 16x7 4" BS Soft 8s
Build- http://www.jeepforum.com/forum/f197/99wjdans-build-thread-1304554/
99WJdan is offline
post #8 of 15 Old 05-02-2012, 05:12 PM
fosterjd79
Agree with everyone that this is normal. Mine does it too. I just try not to force it since having the quadradrive kick in on pavement is rough on the diffs. Better and nicer to make wider turns once you get a feel for it. Save the abuse for the trails.
fosterjd79 is offline
post #9 of 15 Old 05-03-2012, 11:08 AM Thread Starter
VA-WJ
Thank you to everyone who posted! I will rest a little easier this weekend when I take "Ol' Rusty" out on the beach this weekend in the Outer Banks.
I have never noticed the issue off road before but on road in drive-thru's especially, I would hear the binding/rubbing.
VA-WJ is offline
post #10 of 15 Old 05-03-2012, 01:30 PM
imaguy3
You don't notice it off-road b/c the loose traction allows your wheels to travel at slightly diff. speeds easier. When on pavement that doesn't happen as easy, which causes the binding issue. I only notice it when making hard, tight u-turns in town, when I have the steering locked all the way to one direction.
imaguy3 is offline
post #11 of 15 Old 05-03-2012, 04:57 PM
cuttysark
lesson learned. QD systems this is normal. glad nothing is wrong OP
post #12 of 15 Old 05-29-2014, 12:32 PM
jeeplover93
Sorry for resurrecting an old thread...
My dad and step mom have an 02 Limited with Quadradrive. I've been getting it ready for a road trip for them by changing out all of the fluids, this includes the transfer case and diffs. For the transfer case I used Mopar fluid, since a WJJeeps says that's the only thing recommended. For the front and rear diffs I used Valvoline Synthetic for limited slip, 75w-140. My dad noticed that while making a u-turn that there is a horrible rubbing sound now. I took it for a drive and found that the sound seems to be coming from the back of the car and sounds like the rear diff binding up. But as I continued driving and turning in different ways, the sound seemed to go away. I've heard on some cars the diffs won't behave well until the fluid gets warm, I wonder if that is what's going on. A little insight would be very much appreciated!!
jeeplover93 is offline
post #13 of 15 Old 05-29-2014, 02:36 PM
rdkendrick
2003 WJ
Originally Posted by jeeplover93 View Post
Sorry for resurrecting an old thread... My dad and step mom have an 02 Limited with Quadradrive. I've been getting it ready for a road trip for them by changing out all of the fluids, this includes the transfer case and diffs. For the transfer case I used Mopar fluid, since a WJJeeps says that's the only thing recommended. For the front and rear diffs I used Valvoline Synthetic for limited slip, 75w-140. My dad noticed that while making a u-turn that there is a horrible rubbing sound now. I took it for a drive and found that the sound seems to be coming from the back of the car and sounds like the rear diff binding up. But as I continued driving and turning in different ways, the sound seemed to go away. I've heard on some cars the diffs won't behave well until the fluid gets warm, I wonder if that is what's going on. A little insight would be very much appreciated!!
Did you add FM to it, even though the Valvoline says it is added? You might want to get some from a dealership and add, run it in figure 8's until it goes away.
Sent from my iPad using Electrons
rdkendrick is offline
post #14 of 15 Old 05-30-2014, 07:48 AM
pat85
jeeplover93, I used the same stuff you did and I got that growl from my front diff. I went to the dealer and got Mopar's FM. The growl went away in short time.
If it works, it works...do it for you.
His: 01 WJ Storm Trooper
Hers: 14 FDII Patriot
Sold: 98 ZJ
pat85 is offline
post #15 of 15 Old 11-29-2015, 10:35 PM
fiveseven15
bringing up a dead thread, but figured it'd be better than making a new one on the same subject
same issue, binding, but it sounds like its coming from the wheel area itself. fluids were changed about 6k miles ago (mobil 1 gear oil + mopar FM). it didnt do it (or i didnt notice it) until pretty recently. no leaks at the diff (cover & shaft seal) and no leaking from the wheel bearings, i noticed the left side CV boot is torn, but the sound seems like its coming from the right side?
fiveseven15 is offline
Binding on right turns, steering box ? Tezzating WJ Grand Cherokee Forum 4 03-13-2014 11:58 PM
Rear driver side wheel well Rubbing sound when making right turns. Thoughts? specia1k WJ Grand Cherokee Forum 0 12-04-2011 07:34 AM
2004 Jeep GC making annoying ticking sounds!! frosty68 WJ Grand Cherokee Forum 9 08-09-2011 11:13 AM
Question - sounds like tires rubbing against frame... OhioJeep8 WJ Grand Cherokee Forum 5 04-04-2011 12:46 PM
WJ Tranny: shifting problem during sharp turns JCDubya WJ Grand Cherokee Forum 7 08-05-2007 06:25 PM
