RPM spikes at highway speeds - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > RPM spikes at highway speeds
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 12-11-2011, 08:58 AM   #1
dunderrat
We have a 2000 GC and had something odd happen during a road trip yesterday. While at highway speeds (60-70) the tach would hold steady at 2000 rpm but would sporadically spike up 100 to 200 rpm. When this happened the speedometer dropped about 1 mph each time. It would do this with and without cruise control turned on. It also seemed to do it most on flat or slight downhill stretches when there was less load on the engine. Other than this issue there is no noticeable change in engine performance. Any ideas?
dunderrat is offline   Reply With Quote
Unread 12-11-2011, 09:06 AM   #2
seu83
Any howling or any strange noises when this happens. It almost sounds like the tranny is slipping while it's in od. I used to have a camaro that did the same thing. If it was above a certain rpm it wouldn't do it but when it kicked in to od it would start to slip and the rpms would jump a little. Take it for a ride without od and see what it does.
seu83 is offline   Reply With Quote
Unread 12-11-2011, 09:17 AM   #3
dunderrat
No, there wasn't anything else unusual or any odd sounds. It would do it more often at speeds closer to 70 MPH.
Unread 12-11-2011, 09:29 AM   #4
seu83
Is this the 4.7 or the 4.0 and how many miles?
Unread 12-11-2011, 09:57 AM   #5
dunderrat
4.0 with 145,000 miles.
Unread 12-11-2011, 10:09 AM   #6
imaguy3
that sounds identical to what my Jeep was doing a couple months ago, the rpms would go up for just a couple seconds like it was slipping in and out of overdrive...
replaced TPS and all is good. Try it, it's cheap easy and will probably fix your problem, if it doesn't fix your problem it's at least cheap and can't hurt.
imaguy3 is offline   Reply With Quote
Unread 12-11-2011, 10:29 AM   #7
dunderrat
I'll check that out. Am I correct that it should be replaced with a Mopar and not something aftermarket.
Unread 12-11-2011, 10:48 AM   #8
seu83
Yes, it should be a mopar part. The first time I replaced tps on my jeep it cost 200 because first I bought one off of ebay(junk), then autozone, and finally the mopar one. The mopar one was the only one that fixed it.
Unread 12-11-2011, 10:58 AM   #9
imaguy3
I'm taking my chances and I used an autozone one (I know I know), but been no problems for 6 mths...
Rockauto has good prices too
Unread 12-11-2011, 05:35 PM   #10
Bluefish94
Got Mud CNJ 4x4
Bluefish94's Avatar
I'm sure a stupid question when I get the awnser but what is the TPS? Mine does the same thing now and again.
Bluefish94 is offline   Reply With Quote
Unread 12-11-2011, 05:43 PM   #11
the88thpianoman
the88thpianoman's Avatar
2003 WJ
Throttle position sensor.
WJ front drive shaft and fuse panel for sale
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here: Life lessons and budget build
the88thpianoman is offline   Reply With Quote
Unread 12-11-2011, 06:38 PM   #12
Bluefish94
Got Mud CNJ 4x4
Bluefish94's Avatar
Thanks.
