Rough shifts - JeepForum.com
post #1 of 9 Old 06-13-2013, 03:54 PM Thread Starter
scrivenerc
Rough shifts
Recently if i floor it it shifts really hard. Also sometimes when i come to a stop at a light, it will kinda of surge forward a bit and the rpms go up a but. I just replaced the TPS and IAC so they should be go to go. I have a 2000 4.7 with about 153,000 miles on it. Any ideas what cause these issues?
scrivenerc is offline
post #2 of 9 Old 06-14-2013, 06:21 AM Thread Starter
scrivenerc
Could it be time to changr trans fluid?
post #3 of 9 Old 06-14-2013, 06:59 AM
Brandonsdad02
Sounds like its low on tranny fluid. I just did a filter and fluid change on my 00 wj 4.7 and after installing a aux tranny cooler it took 7 1/2 qts to fill it. Make sure you use ATF 4
Brandonsdad02 is offline
post #4 of 9 Old 06-14-2013, 07:07 AM Thread Starter
scrivenerc
I checked the fluid level and its good, doesnt look or smell burnt either.
post #5 of 9 Old 06-14-2013, 07:11 AM
Brandonsdad02
How did you check it? Engine up to normal operating temp and trans in neutral?
post #6 of 9 Old 06-14-2013, 07:14 AM Thread Starter
scrivenerc
Yep
post #7 of 9 Old 06-15-2013, 09:31 AM Thread Starter
scrivenerc
Anyone else with any ideas. Could i need a new PCM or TCM?
post #8 of 9 Old 06-15-2013, 10:44 AM
tim0
check for vacume leaks. PCV could be culprit causing the surge as well.
tim0 is offline
post #9 of 9 Old 06-15-2013, 01:52 PM Thread Starter
scrivenerc
Whats the best way to check for vac leaks?
