Rough idle, cleaned IAC, now worse :( - JeepForum.com
post #1 of 32 Old 07-05-2013, 07:59 PM Thread Starter
steve_80
Tonight I took out my IAC on my 2000 WJ v8 because I've been having rough idling and driving hesitation.
I cleaned it with tb cleaner (sensor safe) and a toothbrush and let it dry. I made sure no spray went into the iac motor. Let it dry then installed it.
I started up no problem and it was quiet, then I drove around the block and the idle kept bouncing from 200-600 rpm likes bouncing ball. It's worse than before I cleaned it.
It was covered in gunk when I cleaned it. So I thought it would run smoothly. I'm out of ideas.
Anyone know why it's now running worse?
steve_80 is offline
post #2 of 32 Old 07-05-2013, 10:02 PM Thread Starter
steve_80
I just took the tb off and cleaned it completely. It's spotless.
Can't test it until tomorrow. Kids sleeping. Damn v8!
If this doesn't work, any suggestions?
steve_80 is offline
post #3 of 32 Old 07-05-2013, 10:56 PM
Jrboarder27
It might be worth it to change out your fuel filter/ pressure regulator. I've heard they can cause rough idle, but not sure about RPM issues.
Jrboarder27 is offline
post #4 of 32 Old 07-06-2013, 04:18 AM
99SK04GTX
Tps?
99SK04GTX is offline
post #5 of 32 Old 07-06-2013, 06:58 AM
rcwj04
Check your tps, but maybe you possibly put it back in upside down?
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #6 of 32 Old 07-06-2013, 08:37 AM Thread Starter
steve_80
i didnt remove the TPS, i followed the cleaning instructions at wjjeeps and it never mentioned to take it off.
should i take it off and clean that too?
steve_80 is offline
post #7 of 32 Old 07-06-2013, 08:42 AM
99WJ539918
Unhook your battery for twenty minutes and let the computer erase the run data. Let me know how it runs after that. Good luck.
Build Thread
99WJ539918 is offline
post #8 of 32 Old 07-06-2013, 08:56 AM Thread Starter
steve_80
both terminals?
steve_80 is offline
post #9 of 32 Old 07-06-2013, 09:33 AM
rcwj04
Just the negative is all you need
rcwj04 is offline
post #10 of 32 Old 07-06-2013, 01:54 PM Thread Starter
steve_80
ok i did that, and drove it for 40minutes, started great and idle is smooth.
ill give it a week to see if it stays smooth. the last time i sprayed TB cleaner in it was smooth like this, but the problem came back after a week or so. But this time i took it off and cleaned the IAC as well.
steve_80 is offline
post #11 of 32 Old 07-06-2013, 08:43 PM
narnwv
narnwv's Avatar
just a note...
you can't clean the TPS. It's a sealed electrical device.
~Aaron
narnwv is offline
post #12 of 32 Old 07-06-2013, 10:29 PM Thread Starter
steve_80
ah ok, then i wont bother taking it off, thanks for the heads up
steve_80 is offline
post #13 of 32 Old 07-07-2013, 02:23 AM
KFLECK
keep me posted on how this is going for you. I seem to have the same problem myself
KFLECK is offline
post #14 of 32 Old 07-07-2013, 07:09 AM
99WJ539918
He's right, but you can unplug it and check for corrosion in the plug, and if there is any you can clean that. Keep us updated, there are a lot of bad idling threads being posted these days.
Build Thread
post #15 of 32 Old 07-08-2013, 09:13 AM
doorjamm
It was just that the computer was so used to the skewed readings that it managed everything off of that with a large compensation and that compensation became normal. Then you cleaned it and it got way different readings which really confused it and caused the rough idling. My jeep did the same thing when I finally decided to fix my o2 sensor relay. I never restarted the computer, but I just drove it for 5 minutes until the roughness went away
doorjamm is offline
