Rough idle black smoke - Page 2 - JeepForum.com
post #16 of 17 Old 05-12-2014, 10:55 PM
Cleaner13
with all due respect you didnt need a scanner, the WJ reads and displays its own codes with the 3 key trick
with that said, I would use a multimeter and test for continuity on the injector harness.
test things before buying parts to throw at it...
also did you read my previous post?
Did you rent a compression checker?....
2001 WJ Limited NV247 4.7
2008 KK Limited MP253 3.7
2008 WK Limited NV245 3.0 CRD
Cleaner13 is offline
post #17 of 17 Old 08-18-2014, 02:18 PM
Tony-NYC
I have a 2001 4.0 6 cylinder with about 140,000 miles (original owner). I get multiple misfire codes and occasional power loss when under strain (pulling a full load) or with 4 adults inside headed up an incline. Flashing check engine light (worried about catalytic converter) and gas rich smell; exhaust spits out black. I changed the condenser pack, checked vacuum lines, changed spark plugs and changed oil. Runs fine in the city but on highway with load problem re-appears. Thought it might be timing chain - any help appreciated.
Tony-NYC is offline
