02-18-2012, 04:41 PM
#1
rotational clunk/thump from front brakes after brake work and lift install
the vehical is a 2004 jeep grand cherokee 4.0L
so i just intalled a 2inch bb lift as well as replacing my front brakes. Pads and rotors. but now, only when driving forward i get a rotational clunk/thumping noise from the front constantly as long as the brakes are being applied. and yes the clunk dose slow down with vehical speed. You can feel it underneith your feet and in the brake pedal when pressing the brakes. and it dosnt change if you go into 4wd nor dose it change if your turning the steering wheel. I re-cheaked the lug nuts,the caliper moutning bolts and caliper braket moutning bolts, even the shocks and front links (everything i took apart/removed). thier is no noises when going over bumps or if you accelorating/coasting with brakes released. Only when applying the brakes dose this happen. now i did find a loose tie rod end when inspecting everything but i dont think that has anything too do with my problem. if somewon could give me a few ideas as were too look or what to inspect i would really appriciat this since i dont feel as its safe too really drive too much like this i am very mechanicly inclined this is just one problem i have never experianced before.
dose anyone think it could be my front drive shaft? sice i installed the lift. the noise dose sound too be almost more center of the front end not so much left or right. but the driveshaft dosnt feel loose i did try and move it.
so again anyhelp would be great thanks
- BUILD THREAD - http://www.jeepforum.com/forum/f197/wj-matt-build-1459459/
- If your not bleeding, you didn't do something right.
- Dude i think i know what your noise is.... your jeep is telling me i need a beer....and your gonna need a bigger wallet.
02-18-2012, 04:58 PM
#2
The drive shaft is a possibility, but I would expect to hear a noise upon any deceleration, not just braking. You could try a quick test and slow the Jeep down using the parking brake and see if you hear the noise from the front, but the best bet is to pop the Jeep back into 2wd and remove the front shaft. It's really easy, just ten 8 mm bolts. Test drive it without a front shaft and see if you hear anything.
02-18-2012, 06:10 PM
#3
Ok yea ill give that a try tomrow. I actully did try the hole rear e brake thing and I had another person outside of the vehical lisen and we bolth agree its indefinitly from the front area. Another thought that I just had was could I have damaged a wheel bearing or an axle shaft wile trying too hammer off the old rotors. I didn't half too hit them too hard but I did give them a couple of good hits with the hammer
02-18-2012, 09:08 PM
#4
Bump for the night
02-19-2012, 07:03 AM
#5
Bump for the morning
02-19-2012, 01:10 PM
#6
Ok I just figured out what the problem was after I pulled the brakes all apart again. Nothing seemed to change nor did I find anything wrong. Well after a little bit of pondering I decided too pull out the front drive shaft for ****s and giggles. Well who would have know, the noise is now gone with the front drive shaft out of the car. So I'm gonna rebuild the drive shaft and get it re balanced. But I figured I would just let people know of what I found incase others run into a simalar problem.
02-19-2012, 01:43 PM
#7
I would not recommend rebuilding the front shaft, depending on the model you have, as there are many replacement options.
http://www.4xshaft.com/
Check out that site, click on the ZJ/WJ link, and let us know which of those four types of drive shafts you have.
02-20-2012, 10:31 AM
#8
Well I have the rezappa - fixed yoke and I just got a quote for a rebult one down the street for 250 bucks what would you recomend?
02-20-2012, 06:15 PM
#9
I'd recommend getting a brand new one with U joints on both ends for less than that cost. www.carolinadriveline.com
11-13-2012, 11:30 PM
#10
Ok cool thank you guys for that comforting info lol I was hoping it wasn't something else and ya I'll look into those drive shafts too
11-14-2012, 06:16 AM
#11
Originally Posted by the88thpianoman
True dat. It is cheaper to get a new one and way better built. I have used both Carolina Driveline and Tom Woods with great results. CD is the best deal going by far though.
2003 Rubicon - 33x12.50x15 GY Duratracs, 15x10 MT Classic Locks, 2" BL, 2" BB, Warn Front Bumper, Garvin ATS Rear Bumper, Body Armor Extreme Rock Rails, Nth Degree Tummy Tucker, Skid Row Engine, LCA and Gas Tank Skid Plates, Teraflex Quick Disco's, Uniden Pro 520xl CB, 3' Firestik Antenna, BW Flat Fender Flares, Tom Woods DS, Currie Rear Adj Arms
11-14-2012, 12:37 PM
#12
I'm betting the driveshaft u-joint. I had a rotational noise that I chased forever.....turned out to be U-joints on the front driveshaft. You changed the angle of the u-joints with the lift. It went away because you removed it and is not stressed when the brakes are applied. This would also be the case if you removed a front axle.
It has been awhile since the original post. Has the problem been solved.
11-14-2012, 09:32 PM
#13
No unfortunately I haven't offically solved the problem yet I need to save some money up to get the new driveshaft but first need to get started on Xmas shopping hmmmm maybe the Gf will buy me one for Xmas lol
11-15-2012, 01:52 PM
#14
I don't understand. Why buy a whole driveshaft when cheap replacement u-joints are only $15.00 at autozone?
11-15-2012, 02:03 PM
#15
The repezza style does not take u-joints. Its a Grand Cherokee thing. Wrangler guys won't understand.
99 WJ Ltd, Blacked out, 4.7L, 242j Swap, 2'' BB, 245/75/16 Kuhmo Venture AT KL78, Flow Master Super 40, MagnaFlow high flow Cat, Akebono caliper upgrade, Addco rear swaybar, Westin brush guard, Moog Super Trail Boss, Rancho RS5000, Rola roof rack with dual kayak J hooks, PAC-AOEM-CHR, Sony Xplod 1200w amp, 2 Sony Xplod 12'' subs, 118,XXX miles ( FOR SALE!)
93 ZJ Ltd, Blacked out, 5.2L, Reman 46RH, Reman 242 Swap, 3.5'' IRO + 2" BB, 33x12.50r15 Mud Claw MTX radials, Bushwacker Flares, 216,XXX miles (Still parked in NC)
04 F-350 SD Crew Cab FX4 Lariat, 6.0 PSD SRW, Head studs, AFE Stage 2 SI Pro Guard 7 intake, Blue Spring mod, 150,XXX Miles
