Rotating in a 5th spare - JeepForum.com
post #1 of 13 Old 06-12-2013, 10:36 PM Thread Starter
thisguyhasadd2
What's the proper way to do so?
Will it matter if the tire has a little less wear
2002 Overland - 4" rc -255/75/17/Jk Moabs
1982 Yamaha XT200J- dead, rebuild winter
Colorado Jeep Club Member#259
thisguyhasadd2 is offline
post #2 of 13 Old 06-12-2013, 10:42 PM
780406jeeper
Here is how I do it. Spare to driver front, driver front to driver rear, driver rear to passenger front, passenger front to passenger rear, passenger rear to spare. Repeat 5k later.
Kevin
'78 Cherokee Chief: 360/TH400/NOS QT, '04 Grand Cherokee: 4.7/545RFE/242HD w/SYE, JK Rubi front axle, 4.56 gears, Protofab rear bumper/tire carrier
780406jeeper is offline
post #3 of 13 Old 06-12-2013, 10:48 PM
fosterjd79
I do it every 3k same day as oil change. Spare to Passenger rear - passenger rear to driver front - driver front to driver rear - driver rear to passenger front - passenger front to spare.
fosterjd79 is offline
post #4 of 13 Old 06-12-2013, 10:51 PM
USFORCES
Pretty much how I do it, really don't matter as long as the fronts go to the rear or spare and they all get rotated and there non directional tires.
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #5 of 13 Old 06-12-2013, 10:52 PM
vmo23
Spare to Passenger rear.
Passenger rear to passenger front.
Passenger front of driver rear.
Driver rear to driver front.
Driver front becomes spare.
What is the difference in the wear of the 4 tires and the spare? Are you talking like 1,000 miles or 10,000?
vmo23 is offline
post #6 of 13 Old 06-12-2013, 11:05 PM
USFORCES
^Better,
USFORCES is offline
post #7 of 13 Old 06-12-2013, 11:12 PM
sinbad85
Originally Posted by vmo23 View Post
spare to passenger rear.
x2
2001 WJ 4.7L-selec-trac/4.5" Teraflex springs\IRO Long arms\Iro adj rear LCA/Bilstien 5100 series shocks/ IRO steering Equalizer/|265/75/16 Goodyear Dura-Tracs on Stock rims\Rear Tube Bumper with carrier|sliders|mopar skids.
sinbad85 is offline
post #8 of 13 Old 06-13-2013, 05:50 AM
maloj2003wj
2006 WK
My reason on starting to do this when i get new tires is that if you have quadradrive you need to be wearing them down evenly, in case you gonna need that spare. Other than that i don't see why to do 5 tire rotation.
2006 WK LIMITED|5.7 HEMI
maloj2003wj is offline
post #9 of 13 Old 06-13-2013, 10:01 AM
forestrat
I bought 4 tires initially when I was new to the quadradrive... a year down the road I bought a spare and had to get it shaved down to match my other tires.
| '02 Grand Cherokee Limited 4.7L H.O. | 3" IRO | Bilstein 5100 | 31.6" 265/70/17 | Superchips 3875 | aFe Cold Air |
forestrat is offline
post #10 of 13 Old 06-13-2013, 12:34 PM Thread Starter
thisguyhasadd2
It's probably around 6k difference. Would a tire shop shave my spare down?
post #11 of 13 Old 06-13-2013, 01:38 PM
forestrat
Get a depth gauge ... The recommended tolerance is within 3/32" of each other.
I don't know where you can get them shaved - I had TireRack shave mine when I ordered it for an extra $25.
Talk about money out the window.
post #12 of 13 Old 06-13-2013, 01:46 PM
lazyWJ
2006 XK Commander
Is QD really this sensitive? Anyone have any real life experience with issues from running unevenly worn tires?
My back of the napkin math says that even if one tire was a full 1/4" taller, on a 30" tire running at 50mph the rotational difference from side to side would be about 5rpm. Unless my math is wrong, as it often is. What's the threshold for these things engaging the clutch?
2004 Imola BMW ZHP
2006 Commander Limited Hemi QD2
"Bought, Not Built"
lazyWJ is offline
post #13 of 13 Old 06-13-2013, 03:57 PM
alfaitalia
I have QT2 with, of course, open dIfs and my hand book still says to do a five wheel rotation....but I can't really see why it would matter too much with open dIfs. Unless you had massive differences in wear front to rear causing the 247 to engage...seems unlikely to me. But I will do it if you guys advise it as now would be a good time to start as a recently fitted five brand new Grabbers!
If you can't fix it with a hammer, you've got yourself an electrical problem!
alfaitalia is offline
