Rocker Rust Repair Quesitons - JeepForum.com
post #1 of 11 Old 09-11-2013, 06:30 PM Thread Starter
lemiller
Hey everyone,
was looking at the WJ today and noticed some rust coming on. Now I know its not as bad as some on here but it still bothers me. As far as fixing it, I'm pretty set on cutting the old out and welding in my own sliders.
That leads me to my questions, can i see some pics of what everyone has done to theirs and if anyone has a good "how-to" or write up could you post a link?
first pic is front passenger side
second pic is of rear passenger side
lemiller is offline
post #2 of 11 Old 09-11-2013, 08:25 PM
tim0
Check out this repair, This is the best rocker repair I have seen.
http://www.jeepforum.com/forum/f310/...-weld-1460733/
tim0 is offline
post #3 of 11 Old 09-16-2013, 07:33 PM Thread Starter
lemiller
timO thank you for the link.
I have been doing tons of research on here and think im going to do something similar to infernored's sliders (pics below). However i would like to know what to expect after cutting out my rockers. whats behind them? things to look out for etc.. Pics would be a great help. Anyone with input I am all ears.
lemiller is offline
post #4 of 11 Old 09-16-2013, 08:56 PM
mycreativename
I have seen infernored's slider/rocker set up in person, and it is a solid looking and feeling piece. I plan on doing the same thing as he has done. He warned me to beware of the foam that is behind the rockers, it can flame up when cutting the old metal out. That's the best I can give you for what I know is behind them.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #5 of 11 Old 09-17-2013, 07:38 AM Thread Starter
lemiller
Thank you i'll keep that in mind.
lemiller is offline
post #6 of 11 Old 09-17-2013, 07:43 AM Thread Starter
lemiller
One question I am having a hard time finding info on is, after I Cut the inner and outer rocker panel off (yes I need to completly remove it to get all the rust) should I tack in some sheet metal to cover the opening then put my slider in place. Or just chop it out and weld in my slider. I can't seem to find any pics of teh process, mostly just before and after pics.
Im lookng to tackle this in the next couple weeks (before it gets cold) so i need all the info I can get. I dont like starting jobs not have any clue what to expect, have never done something like this before.
lemiller is offline
post #7 of 11 Old 05-08-2014, 09:54 AM Thread Starter
lemiller
So I never got a chance to fix my rocker panels.....I plan on starting this project with in the next month (IL winter destoryed my rockers). So rather then start a new thread I figured I would revive my old one. So I'm back to doign research and I am looking for as many pics/ideas/tips/tricks that I can get. Anyone have a "how-to" or "in-progress" pics that they can post or link me to? thanks in advance
lemiller is offline
post #8 of 11 Old 05-09-2014, 01:45 PM Thread Starter
lemiller
Bump: Anyone with more insight?
lemiller is offline
post #9 of 11 Old 05-09-2014, 05:08 PM
icanhithimman
Where do you live?
I chopped mine out, inner and outer. Replaced them with 3x4 structural box steel 3/16 thick. I did not add any sheet steel to cover the hole. I sprayed chassis saver up inside and let it dry before I continued. Then I welded them to the existing body and boxed in the existing rocker panel supports with 1/8 plate. Then used 1x1 angel to close up the gaps and spot welded them to the body. Take the time to pull out your carpet and seats, don't grind or weld need glass it will ruin it. I took out the carpet and found more rust i had to fix. I ended up using chassis saver on the interior floor after i made repairs.
icanhithimman is offline
post #10 of 11 Old 05-12-2014, 12:01 PM Thread Starter
lemiller
Originally Posted by icanhithimman View Post
Where do you live?
I live in Naperville, IL (just outside of chicago) Thanks for the tip about removing the seats and the carpet, didnt think about that. Do you have any pics of yours.
lemiller is offline
post #11 of 11 Old 05-12-2014, 04:36 PM
icanhithimman
Originally Posted by lemiller
i live in naperville, il (just outside of chicago) thanks for the tip about removing the seats and the carpet, didnt think about that. Do you have any pics of yours.
