Rocker rust - JeepForum.com
post #1 of 8 Old 05-10-2013, 07:27 PM Thread Starter
swkenobi
2003 WJ
Rocker rust
Just bought an 03 Limited and noticed on the drivers side a hole in the rocker. Looking closer I see bubbled paint in a few spots. Odd thing is there appears to be some foam behind the whole rocker. Seem to be factory as this is the original sheet metal. Did the factory put some foam behind the rockers, seems like a dumb idea as it would hold moisture in.
swkenobi is offline
post #2 of 8 Old 05-10-2013, 08:57 PM
Stinky7-11
Not in any of mine
Stinky7-11 is online now
post #3 of 8 Old 05-10-2013, 10:11 PM Thread Starter
swkenobi
2003 WJ
Well then someone knowingly put it in there. Interesting.
swkenobi is offline
post #4 of 8 Old 05-10-2013, 10:33 PM
Stinky7-11
Yup, and thats a bad place for it, probe around with an ice pick for soft spots, check with magnet also.
post #5 of 8 Old 05-11-2013, 07:25 PM
mycreativename
There is foam behind mine as well as others that i have seen who have cut out the rockers.
Its for NVH reduction (Noise, Vibration, Harshness) from the factory.
99' WJ, 2.5" Rusty's, Bilstein 5100's, JKS TrackBar, Moog SuperTrailBoss
"With enough fabbing, time & $, it's certainly possible.
That being said, it's like boinkin' your sister...just because you can, doesn't mean you should." - Double E
mycreativename is offline
post #6 of 8 Old 05-13-2013, 09:06 AM Thread Starter
swkenobi
2003 WJ
Wj
So I saw these on Ebay and wondered if anyone had used them. I think the drivers side will need most of it replaced, passenger side only has one spot.
Any thoughts on these rockers?
swkenobi is offline
post #7 of 8 Old 05-13-2013, 09:10 AM
USFORCES
Take it to a body shop have new steel welded in and done right.
04 Overland on 33's, Lift & tires= 8" over stock.
USFORCES is offline
post #8 of 8 Old 05-13-2013, 12:35 PM Thread Starter
swkenobi
2003 WJ
I'd really rather try and do the work myself, just wondering if those rockers are worth the purchase.
swkenobi is offline
