rocker plastic trim - Page 2 - JeepForum.com
post #16 of 25 Old 03-22-2012, 01:11 PM
peytonimor7
Man, I was scared when a few bolts to my caliper were a little rusty yesteryday when I changed pads and rotors, but that looks awful!
l 04 WJ l OME HD+3/4" spacers l Bilstein 5100 l 245/70/17 Firestone M/Ts l IRO A-Arm & CAs F & R l
peytonimor7 is offline
post #17 of 25 Old 03-22-2012, 01:37 PM
VA-WJ
Yeah I know it is bad. I have to think outside of the box to come up with something to replace the rockers that is inexpensive that will look good.
VA-WJ is offline
post #18 of 25 Old 03-22-2012, 01:42 PM Thread Starter
cherokee00SE
Oh god no mines nothing like that. And yeah that's what this tread is about, Laredo rocker trim. I'm looking for some
cherokee00SE is offline
post #19 of 25 Old 03-22-2012, 02:11 PM
VA-WJ
I wish you luck. I was looking at my JY's and they seem to be pretty well picked over.
VA-WJ is offline
post #20 of 25 Old 03-23-2012, 09:14 PM Thread Starter
cherokee00SE
[edit] since it has perforated, it's too late for POR-15. It'll just rust away from the inside and you'll be left with a shell of POR-15.[/QUOTE]
well damn, ill take a shell of por15 over the rusty metal now lol
post #21 of 25 Old 03-24-2012, 06:35 AM
4Tom
Cut the rusty bits off and weld in a rock slider threat the metal then paint and you good to go.
If you do it right not only will it look good but will strengthen your jeep.
WJ 2001 3.1TD
Tom
4Tom is offline
post #22 of 25 Old 03-24-2012, 06:48 AM
asatxj
asatxj's Avatar
Go over to the XJ forums and search a bit. 2x4 box steel makes a great rocker that is quite bomb proof. I did it on my first XJ as the rockers were non existent. Looks good and you have a ton of side impact protection. Doesn't cost much and only a few hours if you or a buddy can weld.
Tip get some Imron Polyurethane Coating and paint it with that. Stuff is hard as a rock! We put it on my brother's wrangler tub and you can hardly get it off with a hammer and chisel (had to have bare metal for a ground).
Jeep Fleet Maintenance Director
'00 WJ, son's Jeep,'01 WJ mine, '04 TJ, brother's Jeep,00 WJ daughter's
Maintain your stuff so you don't have to fix your junk
ASAT= All Season All Terrain
asatxj is offline
post #23 of 25 Old 03-24-2012, 06:50 AM
WJWKXJZJ
I bought our 02 from a fellow in NC. This is what it looks like underneath today.
I went to grad school outside Boston. I am not a fan of the "seas of brine" that the roads become once a few flakes hit.
I sympathize with you all and the woes of the tinworm.
1996 XJ Country 4.0 I won't give it up!
WJWKXJZJ is offline
post #24 of 25 Old 03-26-2012, 03:14 PM
skitch3000
my rockers are pretty bad too. I live in Upstate NY and the road salt ruins everything. I bought replacement rocker panels that I am going to install this week or next. (i will post pictures)... The outer rocker panels have some nasty holes, the inner rocker sill has some bad spots of rust that i will cut out and replace with new sheet metal.. Once i have done all the metal work, i plan on coating with some high zinc, rusty metal primer - then using some bed-liner to make the panel tough. maybe use some POR-15 or chassis black for the pinch-seam and the inner rocker.
skitch3000 is offline
post #25 of 25 Old 03-27-2012, 07:13 PM
14mpg
Check your PMs
14mpg is offline
How do I fix the faded plastic side trim color? 4.0H.O.XJ WJ Grand Cherokee Forum 53 08-30-2014 05:01 AM
Where to get clips for rocker trim etc. Mighty Thor WJ Grand Cherokee Forum 4 07-30-2012 07:48 PM
Rocker panel trim triplett42 WJ Grand Cherokee Forum 8 03-05-2012 08:31 AM
'02 WJ Passenger Side Trim (Rocker Panel Trim?) specia1k WJ Grand Cherokee Forum 0 01-03-2012 06:19 PM
laredo plastic rocker trim cherokee00SE WJ Grand Cherokee Forum 5 10-02-2011 09:03 PM
