Ring Gear Bolt Issues- HELP QUICK - JeepForum.com
post #1 of 6 Old 10-23-2012, 05:24 PM Thread Starter
2000wreckedwj
I am in the process of changing out my gears in my WJ. I have the rear gear set out and have the old ring gear off. I went to install the new ring gear and the original bolts are too big for the new ring gear. The parts seem correct to what I ordered. Anyone have any ideas? Should I just get new bolts or send this gear set back and try another? I need advice ASAP Thanks
2000wreckedwj is offline
post #2 of 6 Old 10-23-2012, 05:57 PM
Planetcat
2010 WK
The ring gear bolts changed in I think 2001. In 1999-2001 or so, they were 3/8" bolts and then went to 7/16" bolts. Almost every part place I've run into doesn't know that there's a difference. At least this was the case with my rear Dana 44A. I'm not sure if this applied to the Dana 35 or not, but sounds like this is your problem. I would return them or you will need to tap/drill out your carrier and ring gear.
2010 WK Laredo 5.7L, 2004 WJ 4.7L (totaled), 1959 CJ-5, 1996 XJ (sold), 1989 YJ Wrangler 4.2L (Sold)
Planetcat is offline
post #3 of 6 Old 10-23-2012, 06:27 PM Thread Starter
2000wreckedwj
thats odd. mine is a 2000. should I order them for a 2002 or 2003 then?
I searched and they are the same part numbers for all the years so I think I would end up getting the same thing I already have. How hard is it to drill and tap that metal? I figure it will be harder than normal metal. Any other options beside drilling them? can I just use the smaller bolts? would it work ok?
post #4 of 6 Old 10-23-2012, 08:02 PM
StrokedWJ
StrokedWJ's Avatar
Where did you order the gear kit from? I'd call them and explain the situation and see what they can do to help. The ring gear with smaller bolt holes will need a carrier with smaller bolt holes as well as smaller ring gear bolts. It would probably be easier to return the gear set and get one with the larger bolt holes.
I may have some of the smaller ring gear bolts saved from my D35 regear a few years ago. Let me know if you want me to look for them...
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #5 of 6 Old 06-15-2013, 11:04 PM
joctavioramos
Wj
I have the same problem you had. How did you fix it? The original bolts are 7/16 and the new ring is for 3/8. Did you get a new part or did you use 3/8 bolts?... need help!!
joctavioramos is offline
post #6 of 6 Old 06-15-2013, 11:22 PM
Planetcat
2010 WK
Wj
Use 3/8" bolts and sleeves in the diff holes. I had to do this on my rear dana 44A, and it's been fine.
