Rezeppa - rezeppa - JeepForum.com
post #1 of 6 Old 03-17-2015, 11:54 AM Thread Starter
MichiganOutlaw
Rezeppa - rezeppa
About a month or so ago I noticed a humming from underneath while going down the road. When I let off the gas, the noise went away. Thinking it was probably the rezeppa(s) on the front d/s I went and ordered rebuild kits for both ends. Haven't had time to install yet, but now I'm getting a grinding/rotational/metal on metal sound. Is this the "normal" progression of the rezeppa/rezeppa d/s; going from humming to grinding/metal sound? I'll be rebuilding it tomorrow.
MichiganOutlaw is offline
post #2 of 6 Old 03-17-2015, 01:37 PM
87thhunter
My stock drive shaft did this, hummed like crazy once and awhile would start to grind. Fixed it with the new CV's
87thhunter is offline
post #3 of 6 Old 03-17-2015, 07:08 PM
Highschool_WJ
That is exactly what mine sounded like when it finally crapped out.
,,,soooo I graduated in 2013...
Highschool_WJ is offline
post #4 of 6 Old 03-17-2015, 07:47 PM
D.J._2000WJ
Build.Beat.Break.Repeat
D.J._2000WJ's Avatar
My WJ was making a lot of noise going down the road and grinding on tight turns (like in parking lots). I checked it out and my CV boots were ripped causing the joits to be full of ***** and getting rusty. I replaced the CV Axles and the Jeep is quiet and smooth again.
D.J._2000WJ is offline
post #5 of 6 Old 03-17-2015, 08:02 PM
rrrcecc
i put a 3in lift in my 01 this past sunday and now im hearing humming and all sorts of wierd grinding sounds.
pulling my DS Friday and hoping thats what the culprit is. prolly gonna have to buy a Double Cardan DS
rrrcecc is offline
post #6 of 6 Old 03-18-2015, 11:08 AM Thread Starter
MichiganOutlaw
Replaced both ends of the front d/s with new kits. No more grinding, etc. The end that connects to the transfer case was totally shot. The rubber boot had failed and inside was pretty rusty.
