Reverse lights - JeepForum.com
post #1 of 7 Old 02-11-2013, 09:18 AM Thread Starter
914pete
Wj Reverse lights
I noticed this weekend when I engage the shifter in reverse my back up lights don't come on. If I leave it engaged (reverse) but pull a little harder on the stick the lights come on.
Does anyone know if there is some sort of adjustment for this or maybe a switch that needs replacing? If so, where is it?
2002 Jeep grand Cherokee Laredo 4.0 original owner, 198,000 miles.
Thanks!
914pete is offline
post #2 of 7 Old 02-11-2013, 09:28 AM
5-90
5-90's Avatar
1988 XJ Cherokee
I'm not sure where the reverse lamp switch is on the 42RE, so I'm going to suggest a trip to the library. Chilton's may tell you were it is, but Motor/Mitchell tells you about as much as the FSM does.
(And start looking for an FSM - you can usually score them relatively cheaply on eBay. <$40 is "relatively cheap," since original price on them runs up around $100-120, new...)
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #3 of 7 Old 02-11-2013, 09:57 AM
buns_1
I think the Neutral Safety Switch triggers the reverse lights on the 4.0.
04 WJ Overland, 3" IRO Lift, Yakima Rack, 255/75/17 BFG KM's, ARB bumper and custom rear bumper.
buns_1 is offline
post #4 of 7 Old 10-11-2013, 01:02 PM Thread Starter
914pete
Yes, it was the neutral safety switch. $28 (OEM) and 5 minutes to replace. Thanks for the help fellas.
914pete is offline
post #5 of 7 Old 10-11-2013, 11:53 PM
doorjamm
Does it for the 45rfe on a 4.7 too?
doorjamm is offline
post #6 of 7 Old 10-12-2013, 11:20 AM
utekking
2014 WK
No it doesn't do it for the 45rfe. That is controlled by the TRS solenoid that is mounted on top of the valve body. I am replacing mine this week for this reason.
utekking is offline
post #7 of 7 Old 10-16-2013, 07:31 PM
utekking
2014 WK
doorjamm, I replaced my TRS assembly and it fixed my light issue. It's a pita but I saved at least $500 doing it myself. There are 2 different assemblies, A white plug and black plug. White is the newer one, it has a different screen filter with it vs the black one. I forget what the internal change was but I was told by the dealership they are interchangeable. My 04 had the black plug even though the 04 is supposed to have the white one. I swapped the black for the white and no issues at all with it.
utekking is offline
