Replacing thermostat housing, 4.0 - JeepForum.com
post #1 of 7 Old 05-07-2013, 05:35 PM Thread Starter
matt726
Hi all, I noticed my thermostat housing is leaking a bit. I was planning on replacing the thermostat, housing and gasket. I have 130,000 miles and as far as I know it's the original water pump. So my question is, since I'm working on the cooling system, should I just go ahead and replace the water pump? No overheating issues, just the slow leak from the housing, any advice is appreciated.
matt726 is offline
post #2 of 7 Old 05-07-2013, 06:03 PM
rcwj04
You can if you want, I don't think you'll need a new housing, a good gasket and some rtv on both sides should be all you need. I just replaced my radiator and thermostat and didn't touch the water pump as it was still in good condition. I guess there is really no way to tell until you look at it
You forget that most members here don't own a crystal ball to tell you exactly what your problem is, specially with bad pictures that don't say/show much of anything... -Jacko84
Just a 19 year old kid with a Jeep, and broke because of it, and loving every moment.
2004 WJ Laredo 4.0 116k
2" BDS coils & Bilstein 5100's | Addco rear swaybar with energy bushings |
K&N FIPK | glasspack | plasti-dipped badges | 17" moabs | HID's, 245/65/17 Cooper Discover AT3 | Rola rack | Fawkes stand alone shackle tabs | Bed lined interior (what a pain that was)
rcwj04 is offline
post #3 of 7 Old 05-07-2013, 06:54 PM
car5car
2002 M-38
Sure, replace waterpump, fuel pump and rear differential and, considering transmission is pretty close, rebuild it too.
Do not replace good parts.
01 XJ 2wd 4.0
car5car is offline
post #4 of 7 Old 05-07-2013, 07:49 PM
BIGBADWOLF
What you need to replace is all the coolant that is left in the block. Since the thermostat housing is off this is a good time to do a thorough flush. Contrary to what some people think GO-5 is just a hybrid version of Dexcool or Prestone Any make/any model. It is organic acid technology and works well if everything is in order. BUT let air get into the system (via a leak) and you will soon have a engine full of acidic coolant. This acidic mess will eat plastic,gaskets and METAL.
BIGBADWOLF is offline
post #5 of 7 Old 05-07-2013, 08:22 PM
rcwj04
Where did you hear this? It may be true but I've never heard this before. Please excuse my ignorance, but you say once air is present it turns into a corrosive acid, so in theory if you left it in the bottle with the cap off long enough it would eat away at the bottle? I find that hard to believe, but hey if it's true than its true haha
rcwj04 is offline
post #6 of 7 Old 05-07-2013, 09:57 PM
BIGBADWOLF
No, nothing would happen in the bottle. However, in the engine once OAT/HOAT breaks down for a number of reasons (air in system,overheating, mixing with ethylene glycol type antifreeze or exceeding the 5 year limit) the coolants protective barrier breaks down. This protective barrier is the ingredient that isolates the water from the iron in your block/head. Once that barrier is compromised iron oxide will begin to form....iron oxide and OAT combined form an EVIL emulsion.
If you ever notice your coolant turning brown you better react ASAP!
post #7 of 7 Old 05-08-2013, 03:48 AM Thread Starter
matt726
Thanks everyone, sounds like just a gasket replace and a cooling system flush. I just wasn't sure on the water pumps condition after 130k, but if it ain't broke, don't fix it I guess.
matt726 is offline
