Replacing the liftgate lock actuator - JeepForum.com
 1Likes
  • 1 Post By blueseasons
post #1 of 11 Old 01-14-2017, 11:30 AM Thread Starter
NoCoCherokee
Has anyone replaced one of these for a 99 WJ? There are plenty of Youtube videos for 98 and earlier. They are not the same mechanism though.
My question is, what actually needs to be replaced? The whole assembly that is mounted to the door metal itself (3x 10mm bolts) or the part that is affixed to that (2x torx bolts)? Does anyone have an OEM part# for the actuator itself?
If I manipulate the lever manually, it will lock and unlock the mechanism so I know all the other parts are working correctly, it is just the actuator I need to replace. Thanks all!
NoCoCherokee is offline
post #2 of 11 Old 01-14-2017, 02:59 PM
blueseasons
I am really not sure what you are asking. But this is the part I replaced when mine krapped out.
http://www.ebay.com/itm/5018479AB-Ne...5XOVKX&vxp=mtr
20 bucks on ebay. free shipping.
blueseasons is offline
post #3 of 11 Old 01-14-2017, 03:58 PM Thread Starter
NoCoCherokee
Was there a picture? I don't see it. Thanks.
post #4 of 11 Old 01-14-2017, 06:48 PM
akinshake
akinshake's Avatar
Mine did the same thing, rock auto has them but I went to the salvage yard, found the cleanest 04 and took that one.
99 4.0 Laredo Selectrac, 6.5" IRO long arms front and rear, 35" KM2, 17" Moab JK wheels,IRO transfer case skid, Clayton D44A truss, 4:56 gears and LSD axle swap.
akinshake is offline
post #5 of 11 Old 01-15-2017, 09:59 AM
blueseasons
post #6 of 11 Old 01-15-2017, 11:34 AM Thread Starter
NoCoCherokee
I checked RockAuto and they have the actuator listed for all 4 doors, but not the liftgate. Did some more checking and they list it as the "trunk lock actuator". Looks like the part #'s match up.
Thanks!
post #7 of 11 Old 09-22-2017, 11:00 PM
MacNCheese
I think I need one of these too. My liftgate doesn't lock. It stays unlocked.
MacNCheese is offline
post #8 of 11 Old 09-23-2017, 08:49 AM
blueseasons1
Pretty easy fix.Watch the video. Should get some new clips to replace the hatch panel. They are longer than the regular door panel clips.
blueseasons1 is offline
post #9 of 11 Old 09-24-2017, 10:33 PM
MojaveMike45
No Tubing required, loosen 5 screws & pop off the panel. Replace that little black plastic actuator thing a ma bob with wires attached to it, 1 small torx screw. You can play with it before removing to see how it should work.
MojaveMike45 is offline
post #10 of 11 Old 09-24-2017, 10:38 PM
Vvrjrlaw
Just be careful when you are removing the interior panel. Disconnect the de-ice wires first before you do anything else. Then use the right tool to pop off the retainers ( have a few on spare because they get brittle and break) and it's basically remove and replace. Just one plug. Did mine about a month ago. Good luck.
Vvrjrlaw is offline
post #11 of 11 Old 09-24-2017, 10:57 PM
MojaveMike45
I did not remove the panel completely, after removing the screws I opened it fully and left it hanging by the top fasteners and supported on the bottom with a piece of bailing wire so as to t it from falling free. There was plenty of room to work easily.
