Replacement bushings for stock track bar - JeepForum.com
post #1 of 14 Old 03-10-2014, 10:14 PM Thread Starter
johnnyham89
Trying to fix up my stock 02 WJ. Running in to some trouble finding replacement bushings for my stock track bar. The only ones that I have found run around $70. Any recommendations for some around $20?
johnnyham89 is offline
post #2 of 14 Old 03-11-2014, 07:43 PM Thread Starter
johnnyham89
Anyone know where I can find a set?
post #3 of 14 Old 03-11-2014, 07:57 PM
MuddyWJ
www.rockauto.com
Might be cheaper to just replace whole setup.
MuddyWJ is offline
post #4 of 14 Old 03-11-2014, 09:10 PM
spud2388
NAPA sells them for $16 a piece. They don't carry them in the store and they have to order them, but the guy told me it would be next day.
spud2388 is offline
post #5 of 14 Old 03-12-2014, 09:10 PM Thread Starter
johnnyham89
Wj
Thanks for the recommendations everyone. After doing some research it looks like I might actually just go with these
http://www.kevinsoffroad.com/cart/ha...leeves-p-1079/
Anyone have any experience with them on a stock track bar? I saw that they might run a little large.
post #6 of 14 Old 03-12-2014, 10:02 PM
MuddyWJ
I have a used set for sale. Pm if you want to save some cash. These things don't soften up.
MuddyWJ is offline
post #7 of 14 Old 03-12-2014, 10:48 PM
peytonimor7
If they fit on a stock track bar I would highly recommend them. They will noticeably tighten up your steering wheel if yours are shot now.
l 04 WJ l OME HD+3/4" spacers l Bilstein 5100 l 245/70/17 Firestone M/Ts l IRO A-Arm & CAs F & R l
peytonimor7 is offline
post #8 of 14 Old 03-13-2014, 06:32 AM Thread Starter
johnnyham89
If I just buy the bushing set without the hardware, do I have to buy another pair of sleeves or can I use the stock ones? That's if they even have sleeves.
post #9 of 14 Old 03-13-2014, 08:51 AM
peytonimor7
I'd say you're good on that, I used stock bolts with a JKS Track Rod and the bolts fit no problem. Should be the same size sleeve.
post #10 of 14 Old 03-13-2014, 10:38 AM Thread Starter
johnnyham89
So the stock track bar does have sleeves that I should be able to reuse with the hard-kor bushings?
post #11 of 14 Old 03-13-2014, 01:14 PM
MuddyWJ
You'll have to remove the bushings from the sleeves.
MuddyWJ is offline
post #12 of 14 Old 03-14-2014, 01:55 PM Thread Starter
johnnyham89
Decided to go with the ones from Napa.
Track Bar Bushing - Front Susp
Part Number: NCP 2749386
http://www.napaonline.com/Catalog/Ca...386_0391080663
What kind of lubrication would y'all recommend I use on these?
post #13 of 14 Old 03-14-2014, 02:13 PM
shockracer
Elbow grease, LOL, jk.
2001 WJ 60th anniversary edition 4.7 quadra-drive
5" hybrid lift, 265/70/17 Guard Dogs load E, bilsteins 5100's, addco sway bars, JKS front quick disco's, JKS adjustable track bar, KOR durometer track bar bushings, IRO crucial path front L.A.s, 1.25" Spidertrax spacers
Colorado Jeep Club Member #262
shockracer is offline
post #14 of 14 Old 03-14-2014, 02:50 PM
MuddyWJ
Sil-glyde from Napa works great.
MuddyWJ is offline
