Replaced heater core . . . - JeepForum.com
post #1 of 11 Old 12-17-2013, 04:58 PM Thread Starter
cr8zynelly
And the new one blew less than 24hrs later.
WTF?!?!?!?
Is this even possible?
cr8zynelly is offline
post #2 of 11 Old 12-17-2013, 08:38 PM Thread Starter
cr8zynelly
PLEASE HELP.
Could I have reversed the coolant lines running to the heater core? Does anyone have a diagram of how they are suppose to connect to the inlet/outlet tubes of the heater core on a 4.7 V8? Thanks.
post #3 of 11 Old 12-17-2013, 09:01 PM
Ravie
Even if you had reversed them all coolant does is run through the lines. Something else is going on. Blocked upstream perhaps..
1999 WJ - Over 10k on the 4.0 rebuild. FB/BDS 2" lift (2.5") w/Bilstein 5125's. General Class Ham...KC0LUA
Burlbook48 sez "Nothing moves a project along faster than cubic dollars." Certified Thread Killer.
Ravie is offline
post #4 of 11 Old 12-18-2013, 07:33 AM Thread Starter
cr8zynelly
I took everything back apart. The heater core was blown. The HVAC box was full of coolant AGAIN.
What do u mean blocked upstream?
When I put everything back together the first I drained the radiator. I ignored the bleeder screw and just filled the rad and left the reservoir open (as was suggested to me by my buddy who is a mechanic). Needless to save that left air in the system and the jeep briefly overheated for maybe a minute. I quickly turned it off and waited for it to cool down before refilling the coolant the proper way as listed on wjjeeps. Everything was fine. I drove the truck home 40 miles and drive it to work the next morning and when I went to leave work I saw a list mist starting from the vents. ; (
I have the new heater already installed in the HVAC box and the box is sealed and ready to be installed. I just want to try and figure out what went wrong so this doesn't happen AGAIN.
1. Briefly overheating with air in the system blew the core?
2. I somehow reversed the lines going to the heater core (which I didn't think mattered)
3. A faulty part (someone would have to die if that's the case)
What's everyone think?? Help please Im trying to get it put back and running as soon as I get off work today so any input would be great. Thanks!!
post #5 of 11 Old 12-18-2013, 08:30 AM
Turbozcs2003
Whos heater core, parts store and manufacturer, probably a bad core.
Turbozcs2003 is offline
post #6 of 11 Old 12-18-2013, 09:16 AM Thread Starter
cr8zynelly
Spectra . . . It's the same one that had been in there since new. 140k on the truck. The new one I got from pep boys appears to be aluminum.
post #7 of 11 Old 12-18-2013, 10:11 AM
Jeeples
Jeeples's Avatar
Use the bleeder screw, that's what it's there for. Chances are you had an air pocket in the core, and as the air pocket heated up it created enough pressure to crack one of the solder welds on your core. Hope your mechanic buddy is willing to help you in the event you damaged the headgasket and/or drop a valve seat since you've overheated the engine.
That heater core looks to be copper, not aluminum. It's also possible that you may have tweaked one of the hard lines coming out of the core when reinstalling. That's the one issue with copper cores, they don't do so well with slight bending as the solder joints can crack easily.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #8 of 11 Old 12-18-2013, 12:11 PM Thread Starter
cr8zynelly
Right, the picture is the one that just blew. I already took that one and replaced it with an aluminum one, last night.
I knew all about the bleeder screw. I read as much as I could before attempting to tackle this project but I'm by no means a mechanic. It's my own fault for going against my better judgement.
I was extremely careful handling the heater core prior to install so I know I didn't tweak or bend anything ,especially, enough to break a solder joint.
I just wondered if that brief overheating is the reason it blew. Wouldn't I have known right away if that was the case? It seems like it didnt actually "blow" til the next morning.
post #9 of 11 Old 12-18-2013, 01:31 PM
brouwmat
It might not of been anything you did.. maybe it was just defective from the git go.
I pondered that myself after doing this a few weeks ago.
Sent from AutoGuide.com Free App
brouwmat is offline
post #10 of 11 Old 12-18-2013, 01:48 PM
rdkendrick
2003 WJ
Maybe, pressure test the new one before you put it in, to make sure it has no leaks.
Sent from my iPad using my fingers
rdkendrick is offline
post #11 of 11 Old 12-22-2013, 07:29 PM Thread Starter
cr8zynelly
Installed another new heater core on Wed night. Everything was fine except the blend air door is now f@$&'d. But it's blowing cold on the drivers side so I believe I can go thru the glove box to replace the actuator.
Went to start it today and I was about to pull out of the driveway when the "coolant low" message appeared. Checked the reservoir and it was almost completely empty. I refilled with g-05 so it's almost impossible to see where it's leaking from with snow on the ground. I refilled the reservoir and left it sitting there. I guess I'll see what happens when I drive it to work in the morning.
