Replaced cv axles now there's a leak! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WJ Grand Cherokee Forum > Replaced cv axles now there's a leak!
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 03-23-2010, 01:43 PM   #1
Blackdout00wj
Ok so I replaced my left and right cv axles but now I have a leak behind the boot between the axle on the passengers side. I wentto an a le shop and they said it may be seals that are next to the chunk but will be serious labor to work on. Any thoughts?
00 WJ 4.7 Quadra drive, 6.5" IRO Long Arms Projector 8k HIDs, Blkd tail lights,Dual intake
Blackdout00wj is offline   Reply With Quote Quick reply to this message
Unread 03-23-2010, 02:00 PM   #2
StrokedWJ
StrokedWJ's Avatar
How long have you had the problem? When you remove the shaft you will spill some gear oil in the axle tube. Its possible that the oil you're seeing is just some left over from the axle shaft swap. If its a lot of fluid coming out or is persistent leaking then I'd have the seals replaced. The seals can be damaged when re-installing the new shaft. To replace the seals you have to almost completely tear down the axle, removing the shafts and carrier.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline   Reply With Quote Quick reply to this message
Unread 03-23-2010, 02:53 PM   #3
xJoshxx
xJoshxx's Avatar
2012 WK
sounds like you hit the seal wrong when replacing the shaft check ur diff fluid level
xJoshxx is offline   Reply With Quote Quick reply to this message
Unread 03-23-2010, 04:16 PM   #4
Blackdout00wj
I'll check the fluid by filling it up to the spill hole. Right before I got on here I was thinking maybe it spilled when I pulled the old shaffts out just as YHC said. I'll get back after I fill it up.
Unread 03-23-2010, 07:54 PM   #5
ratmonkey
R.I.P.
ratmonkey's Avatar
clean it up and see if it continues, the seals are pressed into the tube behind the carrier bearings. it can be a lot of work to do.
ratmonkey is offline   Reply With Quote Quick reply to this message
