Replaced cv axles now there's a leak! - JeepForum.com
post #1 of 5 Old 03-23-2010, 12:43 PM Thread Starter
Blackdout00wj
Ok so I replaced my left and right cv axles but now I have a leak behind the boot between the axle on the passengers side. I wentto an a le shop and they said it may be seals that are next to the chunk but will be serious labor to work on. Any thoughts?
00 WJ 4.7 Quadra drive, 6.5" IRO Long Arms Projector 8k HIDs, Blkd tail lights,Dual intake
Blackdout00wj is offline
post #2 of 5 Old 03-23-2010, 01:00 PM
StrokedWJ
StrokedWJ's Avatar
How long have you had the problem? When you remove the shaft you will spill some gear oil in the axle tube. Its possible that the oil you're seeing is just some left over from the axle shaft swap. If its a lot of fluid coming out or is persistent leaking then I'd have the seals replaced. The seals can be damaged when re-installing the new shaft. To replace the seals you have to almost completely tear down the axle, removing the shafts and carrier.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #3 of 5 Old 03-23-2010, 01:53 PM
xJoshxx
2012 WK
sounds like you hit the seal wrong when replacing the shaft check ur diff fluid level
xJoshxx is offline
post #4 of 5 Old 03-23-2010, 03:16 PM Thread Starter
Blackdout00wj
I'll check the fluid by filling it up to the spill hole. Right before I got on here I was thinking maybe it spilled when I pulled the old shaffts out just as YHC said. I'll get back after I fill it up.
post #5 of 5 Old 03-23-2010, 06:54 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
clean it up and see if it continues, the seals are pressed into the tube behind the carrier bearings. it can be a lot of work to do.
ratmonkey is offline
99 GCL V8 - Front end clicking. Replaced HUBS and AXLES, Still noise. NOCARRIER ZJ Grand Cherokee Forum 30 02-24-2010 01:47 PM
Axles in ZJ Straight six verses axles in Zj V8 deltl1ks ZJ Grand Cherokee Forum 10 01-27-2010 07:34 PM
96 ZJ with a leak. Not an engine leak, an inside leak! gixxerjaker ZJ Grand Cherokee Forum 1 03-04-2008 04:58 PM
engine light - Evaporative Emission Control System Leak Detected (very small leak) sanboy ZJ Grand Cherokee Forum 3 03-14-2006 09:42 AM
I just replaced shocks, brakes, axles in one day! Max Power ZJ Grand Cherokee Forum 7 04-20-2004 06:41 PM
