Repairing coolant return hose? - JeepForum.com
post #1 of 4 Old 07-16-2013, 11:11 PM Thread Starter
snowman91
2003 WJ
Is it possible to repair the coolant return hose from the radiator to the coolant resivor tank? Is there some type of tape I can use? This would be a temp fix so doesn't have to last but I have a pinhole leak.
snowman91 is offline
post #2 of 4 Old 07-16-2013, 11:28 PM
Jer-Bear
Just spend $4 on a new hose. If you can't then use duct tape. It's good for that sort of thing.
/ 2002 WJ 4.7 H.O. / Flowmaster 50 SUV / Magnaflow Cats / Rocking that 2WD! /
Jer-Bear is offline
post #3 of 4 Old 07-17-2013, 09:30 AM
4Tom
You can buy radiator hose repair tape but it will cost nearly as much as new hose and because its a pressurise system tape wont last.
Most parts suppliers and junk yards will have a suitable hose for cheap.
WJ 2001 3.1TD
Tom
4Tom is offline
post #4 of 4 Old 07-17-2013, 09:37 AM
Jeeples
Jeeples's Avatar
That hose doesn't need to hold a lot of pressure. Just use some heat shrink or electrical tape if you're in a pinch. However a few feet of vacuum hose at the local parts store should run you less than a dollar a foot.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
